Hello all,
my company is testing Revit2014 for the 30 days period.
As the network-administrator I had to setup the server in our LAN for server-based central-models.
I installed a "W2008 R2" server
All prerequisites (Application-Server, IIS, listening on port 80 and 808) were ok.
c:\programdata\autodesk\Revit Server 2014\Config\RSN.ini with the ip of the server (no second line in this ini-file)
192.168.70.224
RSROLE2014=Host,Accelerator,Admin
when opening http://revit01/revitServerAdmin2014
we get the error (in German)
Revit Server ist nicht verfügbar. Wenden Sie sich an den Administrator, oder versuchen Sie es erneut.
this is normal, if rsn.ini is not existing, but it is existing.
portquery from a client finds ports 80 135 139 445 808 open on this server
Any hint is appreciated
Thanks for reading this
Günter Zintl
(Munich in Germany)
Solved by guezi. Go to Solution.
Hello all again,
in my test-environment I made an experiment.
revit01 was a server running properly, I shut it down, cloned it, started the clone
then changed the name to revit02, gave new IP, in rsn.ini accordingly
result when opening http://revit02/revitServerAdmin2014
"Revit Server ist nicht verfügbar. ..."
maybe this renaming is causing the error.
in my company first we had revit-server revit01
because of other errors we installed w2008r2 on the same hardware and had to name it revit02 (old server still object in the domain)
your advice is welcome
Günter Zintl
Hello all again,
in my test-environment I installed the server from scratch
new server-name, new IP
all other steps same as before
now all ok
I take this as a solution for my company too
kind regards
Günter Zintl
