While trying to install Revit, I noticed that in the configure installation tab of the installer, the only components listed are Network License Manager, CAD manager tools, Revit Server (which I can't use of course since I'm not installing it on Windows Server), and Revit SDK. The actual revit software isn't there, and once everything is installed there is still no Revit anywhere. Am I missing something here? Like is Revit an addon for vanilla AutoCAD? I was under the impression that it was a completely separate software.
This is on a student license, if it makes any difference.
I also did a complete uninstall, including registry editing, of any and all Autodesk files. I redownloaded the Revit Installer and still no dice.
Solved by rhys.wiebe. Go to Solution.
When you run the Revit installer there is an install button in the lower left that takes you trought the installation wizard. Can you provide a screenshot of where you are getting stuck?
