Installation & Licensing
mattr767
195 Views, 1 Reply
Revit not Installing
I have been trying to download Revit student edition unto my computer but every time I try to install it a screen come up that says
"Installation complete. Some products failed to install" (It's acctually everything that failed to install)
If I am reading it corretly it looks like I'm getting error 1619 which seems to be a common error from what Ive searched.
I tried several things to try and fix it but nothing seems to be working. BTW I am running windows 8.1
I attached the installation log file
1 REPLY 1
dembkod
in reply to: mattr767
mattr767
Hello. You are conflicting with the Microsoft C++ installers. Uninstall the Microsoft C++ from the machine before you run the installer. You will have multiple entries. I would pull them all out.
After this you will likely install just fine.
At this stage, if not, go to the C:\autodesk\ install folder and open the setup.ini file
Search and replace all PREREQ entries with #PREREQ and save the file. Then run the installer.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
