I'm trying to install the Revit MEP 2013 Service Update 2 and receive a 1603 error code.
I've tried all the Various solutions like uninstalling .Net, Uninstall Microsoft Visual C++ 2010 Redistributable, and or Microsoft Visual C++ 2005 Redistributable,
I Installed the Service updates for Revit Architecture 2013 & Revit Structure 2013 with no issues, Only failing with Revit MEP.
OS is Windows 7 64 Bit.
Can Anyone help?
Hi Callum,
Thank you for including the install logs that were posted to the Forums thread. The cp_Install.log appears to have some connection issues to connect back to the original install source for the Content:
!=> 404 when attempt to access /download/2013RME_RTM/Content/Revit/ko/ASM-ko-XX-m-Famtem.xml
Has something changed in the configuration of your system since you first installed the application?
Did you install from a network deployment, media or install image? Perhaps you will need to have the original install media available in the same location again.
Patching has a specific mechanism whereby it has to verify the files detected on the system (Installed) and compare to the original source files to determine whether the patch file can be applied.
If you are unable to get the machine back to the original state, you can always use the workaround of uninstalling, then install again but this time choose to have the update included in the install.
Please let me know if this helps. Thank you.
Cheers,
Alison
Log files attached,
I've used the msicrosoft fixit utility, with out any result, Have not tried the Uninstall as yet, wanted to leave that as a last resort. Th origional install was from a central deployment disk.
