Installation & Licensing
Revit MEP 2013 Licence query
3 REPLIES 3
BIM_01
371 Views, 3 Replies
we have upgraded some license to 2014 ans still we have 7 network license of Revit 2013 BDS.
my Question is can i use Revit 2011,2012 product with this licenses??
Please help me
Vineet
BIM Manager
If I Help you, Please give Kudos 🙂
Tags (1)
3 REPLIES 3
TravisNave
in reply to: BIM_01
Yes.  If your 2014 is under Subscription then your 2014 license file will already be encoded for you to use any combination of your 7 seats as 2011-2014.
Autodesk Forums:
BIM_01
in reply to: TravisNave
Thanks for your quick reply,
i wanna like to conformation  from you that
we have total 12 BDS of 2014 which is upgraded. i know i use 2011-12-13 product with that 2014 products.
but we haven’t upgraded 7 Revit 2013 BDS. so my que is can i use 2011-2012 product with that 2013 BDS licenses ??
kindly Hellp
Vineet
BIM Manager
TravisNave
in reply to: BIM_01
If the 2013 is under Subscription, then yes.  If not, then no.
Also, since there is a lot of cascading of licensing that crosses over between those suites, you will want to regenerate your 2013 file on the same date as your new 2014 file to properly combine.
Autodesk Forums:
Administrator Productivity
