Hello, I have Windows 7 Ultimate 64bit and I am trying to install Revit LT 2014, and the installation won't start. I double click Setup and nothing happens. I tried using compatibility, but the only one that tried to work was Windows XP (service pack 2 or 3), but since Revit LT isn't compatible with Windows XP, the installation stops with an error about compatibility. The other compatibility options don't work. I had the same problem with Design Suite Ultimate 2014 and Inventor LT 2014 but using Windows XP compatibility allowed the programs to be installed, but not this time. Any help would be greatly appreciated.
Include the log file from the installation summary screen or your %TEMP% folder. I suspect there is another reason for your failure.
There are no errors displayed. Nothing seems to happen when I double click setup. If I have task manager open, setup comes up under processes and then quickly disappears. When I try to use compatibility, the installation starts but then give s the error about not being compatible with this version of Windows.
I wouldn't attach the log file before. At least I don't think it did.
Have you tried right-clicking the setup.exe and Run as Administrator?
Also make sure the UAC is off and your anti-virus is disabled.
I've tried all of that and I even uninstalled Norton, but still the same problem.
