Installation & Licensing
Revit LT 2014 fails to install library
1 REPLY 1
egbu3sg
3268 Views, 1 Reply
I have been working with 3 different techs for 3 days trying to install this licensed software on my laptop. It has Windows 7, 64 bit. It will download fine, then do most of the install but then stops when it's almost finished and says "Material Library could not install/uninstall. Please close all programs and try again." It installs everything onto my hard drive, it just won't finish the setup, therefore making it unusable. The last thing the tech was going to have me try was to send him my setup.ini file so he could edit it to make the setup completely bypass the base images install files. I have located them, I just don't know how to edit the script properly to make it skip them. If anyone knows how to edit this please let me know. To locate it, if you scroll about halfway down, it is below 3rd pary tools, then beneath "common autodesk content." It is the [CMILB2014] stuff and below
this is the entire setup.ini file and it's also attached:
[SETUP]
SETUP_CODE={7346B4A0-1400-0400-0000-705C0D862004}
SETUP_ICON=SetupRes\Revit_LT.ico
TITLE=\Autodesk Revit LT 2014
LOG=%tmp%\Autodesk Revit LT 2014 Setup.log
EVALMSI=SetupRes\eval.msi
PRIMARY_MSI=x86\RLT2014\RLT2014.msi
SYSUPDATE=MSI
RESOURCE_PATH=%lang%\SetupRes
LPMODE=NO_UI
DEFAULTMEDIALANGUAGE=en-US
DOCUMENT_LINK=Documentation\help-relay-page-online-revit.html
DOCUMENT_FALLBACK_LINK=Documentation\help-relay-page-offline-revit.html
SUPPORT_LINK=Documentation\readme-redirect-RLT.htm
SUPPORT_FALLBACK_LINK=Documentation\Readme\RLT Readme.htm
SYSTEMREQUIRE_LINK=Documentation\sysreq-redirect-revit.htm
SYSTEMREQUIRE_FALLBACK_LINK=Documentation\SysReq\autodesk_revit_product_line_system_requirements_and_recommendations_final.pdf
EULA_LINK=http://www.autodesk.com
INSTALL_PATH=%ProgramFiles%\Autodesk
CREATE_DESKTOP_SHORTCUT=YES
SETUP_HIGHLIGHT_COLOR=#9955AA
#==================== Platform Requirement
OSMAJVER=6
OSMINVER=0
SPMAJVER=0
#==================== Graphics Card Check
#OGS_XML_FILE=Setup\OgsTest.xml
#==================== Install Execute & UI Sequence
EXE_SEQUENCE=RLT2014;CMILM2014;NLM;CADM;ADDONS
INSTALL_SEQUENCE=NLM;CADM;RLT2014;CMILM2014;ADDONS
UI_SEQUENCE=LaunchDlg;BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;RLT2014;CMILM2014;NLM;CADM;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg;ADDONS
#==================== UI
UI_MODE=
#==================== Deployment Info
DEPLOYMENT_NAME=
CLIENT_LOGGING=YES
EXTRA_FILES=REVIT;*.exe:eula:nlsdl:Setup:SetupRes:%lang%:3rdParty\MSI:Content
#==================== AdLM ProdKey Info
ADLM_CONFIG_FILE=Setup\RevitLTConfig.pit
ADLM_PIT_DLL=Setup\adlmPIT.dll
ADLM_VERSION=2014.0.0.F
ADLM_TRIAL_DAYS=30
#==================== Custom Callback
CB_FUNC=CustomCallbackRevitOSVersionCheck
CB_SOURCE=Setup\RevitSetup.dll
CB_PARAM=7.0.5730;7.0
CB_DESCRIPTION=Detecting Revit Supported Platforms
#==================== Global MSI Properties
PATH_LENGTH=149
SETUP_TYPE=9
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/SETUP_%platform%.tar.lzma2
DOWNLOAD_UNCOMPSIZE=73081061;101554919
DOWNLOAD_COMPSIZE=41054598;48587692
RELEASE_GUID={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}
WEB=YES
AVAILABLELANGUAGES=en-US
USE_REMOVABLE_DRIVE=NO
[GLOBAL_MSI_PROPERTIES]
[MSI]
#== This is duplicated from [MSI4]
#== This is only needed if you list MSI in SYSUPDATE
PLATFORM=ALL
PRODUCT_NAME=Windows Installer Redistributable
EXE_PATH=3rdParty\MSI
EXE_PARAM=/quiet /norestart
VC_FUNC=MsiVerCheck
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=4.0
VC_DESCRIPTION=Detecting MSI
#==================== REVIT
DOWNLOAD_UNCOMPSIZE=47945808
DOWNLOAD_COMPSIZE=47513314
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/MSI.tar.lzma2
[RLT2014]
PRODUCT_NAME=Autodesk® Revit® LT 2014
EXE_PATH=x86\RLT2014\RLT2014.msi
EXE64_PATH=x64\RLT2014\RLT2014.msi
LOG=%tmp%\Autodesk Revit LT 2014 Install.log
PRODUCT_MESSAGE=RevitSetupRes.dll;305
PLATFORM=NATIVE
ADMIN_INSTALL=NO
PREREQUISITE=RevitOSVersionCheck;IE7;SSE2;VCREDIST2008SP1X64;VCREDIST2008SP1X64_6161;VCREDIST2005X86;VCREDIST2005X64;VCREDIST2008SP1X86;VCREDIST2008SP1X86_6161;VCREDIST2010SP1X86;VCREDIST2010SP1X64;KB958314ATLX86;KB958314MFCX86;KB958314CRTX86;KB958314OPENMPX86;KB958314ATLX64;KB958314MFCX64;KB958314CRTX64;KB958314OPENMPX64;VCREDIST2005SP1ATLX86;VCREDIST2005SP1ATLX64;_DOTNET35SP1;DOTNET45;DOTNET45LANG;DIRECTX;FaroSDK;
#LS PREREQUISITE=
POSTREQUISITE=CM2014;CMILB2014;CMILL2014
EXE_PARAM=
ACTION=INSTALL
REMOVE_PATH=
ROLLBACKABLE=YES
USE_EXTERNAL_UI=YES
UI_SEQUENCE=RevitShortcutPanel;RevitSettingsPage;RevitContentPackPanel;RevitConfigFolderPanel;AddAdditionalFilesPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage;RevitServerAddressPanel
MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;RevitContentPackDialog;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
DISKCOST_FUNC=BSDGetDiskCost
DISKCOST_SOURCE=Setup\RevitContentPackUI.dll
INSTALL_FINALIZE=ContentPackFinalize
INSTALL_FINALIZE_SOURCE=Setup\RevitContentPackUI.dll
ALLOW_ADD_REMOVE=YES
EULA_PATH=eula
LPMODE=MUI
MUILPLINK=http://www.autodesk.com/revitlt-languagepacks
MSINEWINSTANCE=1
DEPLOYMENTLANGUAGE=en-US
DISK_PROMPT=RevitSetupRes.dll;108
DISK_LABEL=RLT2014
DOWNLOAD_UNCOMPSIZE=1626268484;1789774460
DOWNLOAD_COMPSIZE=636211427;666477725
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/RLT2014_x86.tar.lzma2;{FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/RLT2014_x64.tar.lzma2
[RLT2014_LANGPACK]
PRODUCT_NAME=Autodesk® Revit® LT 2014 Language Pack
EXE_PATH=x86\%lang%\RLT2014\RLT2014LP.msi
EXE64_PATH=x64\%lang%\RLT2014\RLT2014LP.msi
ADMIN_INSTALL=NO
LOG=%tmp%\Autodesk Revit LT 2014 LangPack Install.log
[RLT2014_en-US]
DISK_LABEL=RLT2014
DOWNLOAD_UNCOMPSIZE=65205167;68360111
DOWNLOAD_COMPSIZE=16290778;16736062
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/RLT2014_x86_en-US.tar.lzma2;{FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/RLT2014_x64_en-US.tar.lzma2
[RevitShortcutPanel]
UI_CREATOR=RevitShortcutPanel
UI_SOURCE=Setup\RevitSetup.dll
[RevitOSVersionCheck]
VC_FUNC=RevitOSVersionCheck
VC_SOURCE=Setup\RevitSetup.dll
VC_PARAM=7.0.5730;7.0
VC_DESCRIPTION=Detecting Revit Supported Platforms
#==================== REVIT Server
[REVITSERVER]
PLATFORM=x64
PRODUCT_NAME=Revit Server
PRODUCT_MESSAGE=RevitSetupRes.dll;503
PREREQUISITE=RevitServerOsVerCheck;DOTNET45;DOTNET45LANG
PRODUCT_GROUP=
EULA_PATH=eula
LOG=%tmp%\Autodesk Revit Server 2014 Install.log
EXE_PATH=%platform%\Tools\RS2014\RevitServer.msi
UI_SEQUENCE=RevitServerRolesPanel;RevitServerUsersPanel
INSTALL_TYPE=4
IGNORE_FAILURE=NO
DOWNLOAD_UNCOMPSIZE=28627320
DOWNLOAD_COMPSIZE=6442830
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/REVITSERVER.tar.lzma2
[RevitServerAddressPanel]
UI_CREATOR=RevitServerAddressPanel
UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[RevitServerRolesPanel]
UI_CREATOR=RevitServerRolesPanel
[RevitServerUsersPanel]
UI_CREATOR=RevitServerUsersPanel
[RevitServerOsVerCheck]
VC_FUNC=RevitServerOsVerCheck
VC_DESCRIPTION=Detecting Windows Server 2008
#==================== Modified Main Pages: Install Mode
[ADDONS]
INSTALL_TYPE=2
PRODUCT_NAME=\setupres.dll;189
PRODUCT_MESSAGE=SetupRes.dll;187
ACTION=INSTALL
UI_SEQUENCE=AddAddonPage
[LaunchDlg]
UI_CREATOR=LaunchDialog
UI_SOURCE=Setup\SetupAcadUi.dll
UI_CONSTRUCT_SOURCE=Setup\RevitContentPackUI.dll
UI_CONSTRUCT=cp_LaunchDlgConstruct
[ProductSelectionDlg2]
UI_CREATOR=ProductSelectionDialog2
UI_CONSTRUCT=SelectionDlgConstruct
UI_FINALIZE=RevitCreateCustomIni
UI_FINALIZE_SOURCE=Setup\RevitSetup.dll
#== The background image could change for you
[ProductInfoDlg]
UI_CREATOR=ProductInfoDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS" AND NOT ADSK_OEMPREINSTALL
UI_FINALIZE=ContentNetCheck
UI_FINALIZE_SOURCE=Setup\RevitContentPackUI.dll
[FullProgressDlg]
UI_CREATOR=FullProgressDialog
UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images
UI_INFOTAINMENT_ELAPSE=18000
UI_CONSTRUCT_SOURCE=Setup\RevitSetup.dll
UI_CONSTRUCT=RevitDownloadContent
#================ Needed by REVIT =======================================================
[SDK]
PLATFORM=ALL
PRODUCT_NAME=Revit Software Development Kit
PRODUCT_GROUP=Supplemental Tools
EXE_PATH=Utilities\SDK\RevitSDK.exe
EXE_PARAM=-d"%SystemDrive%\Revit SDK 2014"
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
DISKCOST=300000000
DOWNLOAD_UNCOMPSIZE=201066482
DOWNLOAD_COMPSIZE=192733424
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/SDK.tar.lzma2
[KB958314ATLX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\ATL\vc_atlx86runtime.msi
DOWNLOAD_UNCOMPSIZE=77809
DOWNLOAD_COMPSIZE=78582
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314ATLX86.tar.lzma2
[KB958314MFCX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (MFC) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\MFC\vc_mfcx86runtime.msi
DOWNLOAD_UNCOMPSIZE=7029134
DOWNLOAD_COMPSIZE=7009707
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314MFCX86.tar.lzma2
[KB958314CRTX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (CRT) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\CRT\vc_crtx86runtime.msi
DOWNLOAD_UNCOMPSIZE=866975
DOWNLOAD_COMPSIZE=866274
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314CRTX86.tar.lzma2
[KB958314OPENMPX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\OpenMP\vc_openmpx86runtime.msi
DOWNLOAD_UNCOMPSIZE=57231
DOWNLOAD_COMPSIZE=56924
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314OPENMPX86.tar.lzma2
[KB958314ATLX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\ATL\vc_atlx64runtime.msi
DOWNLOAD_UNCOMPSIZE=79915
DOWNLOAD_COMPSIZE=80732
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314ATLX64.tar.lzma2
[KB958314MFCX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (MFC) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\MFC\vc_mfcx64runtime.msi
DOWNLOAD_UNCOMPSIZE=7946166
DOWNLOAD_COMPSIZE=7916620
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314MFCX64.tar.lzma2
[KB958314CRTX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (CRT) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\CRT\vc_crtx64runtime.msi
DOWNLOAD_UNCOMPSIZE=949074
DOWNLOAD_COMPSIZE=948699
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314CRTX64.tar.lzma2
[KB958314OPENMPX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\OpenMP\vc_openmpx64runtime.msi
DOWNLOAD_UNCOMPSIZE=58572
DOWNLOAD_COMPSIZE=58366
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/KB958314OPENMPX64.tar.lzma2
[IE7]
PRODUCT_NAME=Internet Explorer 7
PRODUCT_MESSAGE=SetupRes.dll;209
VC_FUNC=IeVerCheck
VC_DESCRIPTION=Detecting Internet Explorer 7
ACTION=INSTALL
EXE_PATH=NULL
#================================================= Autodesk tools ============================================================
[NLM]
PLATFORM=NATIVE
PRODUCT_NAME=Network License Manager
PRODUCT_MESSAGE=AcSetupRes.dll;47
LOG=%tmp%\NLM Install.log
EXE_PATH=%platform%\%lang%\Tools\NLM\NLM.msi
EXE_PARAM=ALLUSERS=1
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
DISKCOST=8000000
#== Add more available languages
LPMODE=MLD_ADR
EULA_PATH=EULA
[CADM]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk CAD Manager Tools
PRODUCT_MESSAGE=AcSetupRes.dll;46
PREREQUISITE=SSE2
LOG=%tmp%\CADManager Install.log
EXE_PATH=%platform%\%lang%\Tools\CADManager\CADManager.msi
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
LPMODE=MLD_ADR
EULA_PATH=EULA
#================================================= 3rd Party tools ============================================================
[WORKFLOWS]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk Workflows 2014
LOG=%tmp%\Workflows 2014 Install.log
EXE_PATH=3rdParty\%platform%\Workflows\Workflow_%platform%.msi
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
#================================================= Common Autodesk Content ============================================================
[CM2014]
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86
PRODUCT_NAME=Autodesk Material Library 2014
EXE_PATH=Content\ADSKMaterials\2014\CM\MaterialLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\CM\*.cab
ADMIN_INSTALL=NO
DISKCOST=88100000
EULA_PATH=eula
ACTION=INSTALL
DOWNLOAD_UNCOMPSIZE=54567570
DOWNLOAD_COMPSIZE=51113085
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/CM2014.tar.lzma2
[CMILB2014]
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86;CM2014
PRODUCT_NAME=Autodesk Material Library 2014 - Base Image Library
EXE_PATH=Content\ADSKMaterials\2014\ILB\BaseImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILB.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILB\*.cab
ADMIN_INSTALL=NO
DISKCOST=82900000
EULA_PATH=eula
ACTION=INSTALL
DOWNLOAD_UNCOMPSIZE=69545542
DOWNLOAD_COMPSIZE=69522710
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/CMILB2014.tar.lzma2
[CMILL2014]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2014 - Low Image Library
EXE_PATH=Content\ADSKMaterials\2014\ILL\LowImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILL.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILL\*.cab
ADMIN_INSTALL=NO
DISKCOST=258000000
EULA_PATH=eula
ACTION=INSTALL
DOWNLOAD_UNCOMPSIZE=246287006
DOWNLOAD_COMPSIZE=245841580
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/CMILL2014.tar.lzma2
[CMILM2014]
SHARED_COMPONENT=YES
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86;CM2014;CMILB2014;CMILL2014
PRODUCT_NAME=Autodesk Material Library 2014 - Medium Image Library
PRODUCT_MESSAGE=AcSetupRes.dll;61
EXE_PATH=Content\ADSKMaterials\2014\ILM\MediumImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILM\*.cab
ROLLBACKABLE=YES
ALLOW_ADD_REMOVE=NO
ADMIN_INSTALL=NO
DISKCOST=762000000
EULA_PATH=eula
#== Uncomment the line below if you want it installed by default
ACTION=INSTALL
#================================================= Common Autodesk Components ============================================================
#================================================= 3rd Party Components ============================================================
#== Note about 3rdParty licenses:
#== If 3rdParty component licenses need to be included in the media, put them in 3rdParty\Licenses folder.
#== Taking the example of Revit Architecture:
#== RAC2012\3rdParty\Licenses\
#== - GNU
#== - Mozilla Public License
#== You may be required to ship the source code to the 3rd party components, for example QT (free license).
#== Put the source code in the 3rdParty\Source\[ComponentName{VerX.X}] folder. You must add a version number to the component so it does not conflict with other products.
#== For example:
#== RAC2012\3rdParty\Source\QT5.5\
DOWNLOAD_UNCOMPSIZE=749540780
DOWNLOAD_COMPSIZE=746686164
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/CMILM2014.tar.lzma2
[MSI4]
PLATFORM=ALL
VC_FUNC=MsiVerCheck
VC_PARAM=4.0
[NLSDL]
PLATFORM=NATIVE
PRODUCT_NAME=Microsoft NLS Downlevel APIs
EXE_PATH=NLSDL\nlsdl.x86.exe
EXE64_PATH=NLSDL\nlsdl.amd64.exe
IGNORE_FAILURE=YES
#============= VCREDIST Begin ===============
#== Note about VCREDIST section names used:
#== The template uses a naming that matches the MSDN download name. It doesn’t use a version number.
#== For example, if you downloaded the package from http://www.microsoft.com/downloads/en/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-3802b2af5fc2&dis...
#== you would use [VCREDIST2008SP1X86] in the INI.
[VCREDIST2010SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe
EXE_PARAM=/q /norestart
VC_FUNC=VCx86RedisCheck
VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
IGNORE_ERROR=5100
DOWNLOAD_UNCOMPSIZE=4995416
DOWNLOAD_COMPSIZE=4970603
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2010SP1X86.tar.lzma2
[VCREDIST2010SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe
VC_FUNC=VCx64RedisCheck
VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7}
IGNORE_ERROR=5100
DOWNLOAD_UNCOMPSIZE=5673816
DOWNLOAD_COMPSIZE=5648785
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2010SP1X64.tar.lzma2
[VCREDIST2008SP1X86_6161]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161
EXE_PATH=3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={9BE518E6-ECC6-35A9-88E4-87755C07200F}
DOWNLOAD_UNCOMPSIZE=4479832
DOWNLOAD_COMPSIZE=4458629
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2008SP1X86_6161.tar.lzma2
[VCREDIST2008SP1X64_6161]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}
DOWNLOAD_UNCOMPSIZE=5207896
DOWNLOAD_COMPSIZE=5175034
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2008SP1X64_6161.tar.lzma2
PLATFORM=ALL
EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
DOWNLOAD_UNCOMPSIZE=4485976
DOWNLOAD_COMPSIZE=4464851
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2008SP1X86.tar.lzma2
[VCREDIST2008SP1X64]
PLATFORM=x64
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6}
DOWNLOAD_UNCOMPSIZE=5225304
DOWNLOAD_COMPSIZE=5199638
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2008SP1X64.tar.lzma2
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x86_2005.log"" "
VC_PARAM={837b34e3-7c30-493c-8f6a-2b0f04e2912c}
DOWNLOAD_UNCOMPSIZE=2745256
DOWNLOAD_COMPSIZE=2701889
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2005SP1ATLX86.tar.lzma2
[VCREDIST2005SP1ATLX64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64_2005.log"" "
VC_PARAM={6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}
DOWNLOAD_UNCOMPSIZE=3215280
DOWNLOAD_COMPSIZE=3172496
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2005SP1ATLX64.tar.lzma2
[VCREDIST2005X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005\vcredist_x86.exe
VC_PARAM={7299052B-02A4-4627-81F2-1818DA5D550D}
DOWNLOAD_UNCOMPSIZE=2723264
DOWNLOAD_COMPSIZE=2680079
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2005X86.tar.lzma2
[VCREDIST2005X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005\vcredist_x64.exe
VC_PARAM={071C9B48-7C32-4621-A0AC-3F809523288F}
#============= VCREDIST End ===============
DOWNLOAD_UNCOMPSIZE=3200960
DOWNLOAD_COMPSIZE=3157800
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/VCREDIST2005X64.tar.lzma2
[SSE2]
PRODUCT_NAME=SSE2 Support Check
PRODUCT_MESSAGE=SSE2 Support Check
EXE_PATH=NULL
VC_FUNC=CheckForSSE2Support
VC_DESCRIPTION=SSE2 Support Check
#============= DOTNET Begin ===============
[DOTNET45]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe
VC_FUNC=DotnetVerify
VC_PARAM=.NET Framework 4.5
VC_DESCRIPTION=Detecting .NET 4.5 Runtime
DISKCOST=816640000
DOWNLOAD_UNCOMPSIZE=143835168
DOWNLOAD_COMPSIZE=138958314
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/DOTNET45.tar.lzma2
[DOTNET45LANG]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5 Language pack
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45LP_Full_x86_x64_%lcid%.exe
AVAILABLELANGUAGES=1025;1028;1029;1030;1031;1032;1035;1036;1037;1038;1040;1041;1042;1044;1045;1046;1049;1053;1055;2052;2070;3082
VC_FUNC=DotnetLangPacksVerCheck
VC_PARAM=%lcid%;4.5.50709
LPMODE=MLD_ADR
IGNORE_LANGS=1033
IGNORE_FAILURE=YES
DISKCOST=3000000
[_DOTNET35SP1]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 3.5 SP1
EXE_PATH=3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe
VC_PARAM=.NET Framework 3.5 SP1
VC_DESCRIPTION=Detecting .NET Runtime 3.5 SP1
DISKCOST=80000000
IGNORE_FAILURE=NO
#============= DOTNET End ===============
DOWNLOAD_UNCOMPSIZE=242856912
DOWNLOAD_COMPSIZE=231448030
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/_DOTNET35SP1.tar.lzma2
[DIRECTX]
PLATFORM=ALL
PREREQUISITE=_DOTNET35SP1
PRODUCT_NAME=DirectX® Runtime
EXE_PATH=3rdParty\DirectX\DXSETUP.exe
EXE_PARAM=/silent
IGNORE_FAILURE=YES
DISKCOST=50000000
DOWNLOAD_UNCOMPSIZE=8872120
DOWNLOAD_COMPSIZE=6793233
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/DIRECTX.tar.lzma2
[FaroSDK]
PLATFORM=NATIVE
PRODUCT_NAME=FaroSDK
EXE_PATH=3rdParty\%platform%\FaroSDK\FARO.LS_5.1.0.30630.msi
LOG="%tmp%\FaroSDK.log"
ACTION=INSTALL
IGNORE_FAILURE=YES
#==================== Common Main Pages: Install Mode
DOWNLOAD_UNCOMPSIZE=10321920;13414400
DOWNLOAD_COMPSIZE=10236442;13232446
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/FaroSDK_x86.tar.lzma2;{FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/FaroSDK_x64.tar.lzma2
[LicenseDlg]
UI_CREATOR=LicenseDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL
[InstallCompleteDlg]
UI_CREATOR=InstallCompleteDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT"
#==================== Common Main Pages: Deploy Mode
[BeginDeploymentDlg]
UI_CREATOR=BeginDeploymentDialog
UI_SOURCE=Setup\DeployUi.dll
[DeploymentCompleteDlg]
UI_CREATOR=DeploymentCompleteDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED
[DeploymentFailedDlg]
UI_CREATOR=DeploymentFailedDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED
#==================== Common Config pages: Install Mode
[InstallTypePage]
UI_CREATOR=InstallTypePage
[RevitContentPackPanel]
UI_CREATOR=ContentPackPage
UI_SOURCE=Setup\RevitContentPackUI.dll
[RevitConfigFolderPanel]
UI_CREATOR=ConfigFolderPage
[DisciplinePage]
UI_CREATOR=RevitDisciplinePanel
[UKResPage]
UI_CREATOR=RevitUKResPanel
#==================== Common Config Pages: Deploy Mode
[ContentLocationPage]
UI_CREATOR=ContentLocationPage
[PathCustomizationPage]
UI_CREATOR=PathCustomizationPage
[AddAdditionalFilesPage]
UI_CREATOR=AddAdditionalFilesPage
[WorkstationSettingPage]
UI_CREATOR=WorkstationSettingPage
[ServicePackPageForDeploy]
UI_CREATOR=ServicePackPage
[ServicePackPageForInstall]
UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[InfoCenterCommCenterPage]
UI_CREATOR=InfoCenterCommCenterPage
[OnlineResourcesPage]
UI_CREATOR=OnlineResourcesPage
UI_POSTCONSTRUCT_SOURCE=Setup\RevitSetup.dll
UI_POSTCONSTRUCT=OnlineResourcesPostConstruct
[RevitSettingsPage]
UI_CREATOR=RevitSettingsPanel
#==================== Common Main Pages: Maintenance Mode
[MaintenanceDlg]
UI_CREATOR=MaintenanceDialog
[AddRemoveFeaturesDlg]
UI_CREATOR=AddRemoveFeaturesDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL"
[RepairDlg]
UI_CREATOR=RepairDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL"
[MaintVerifyReadyDlg]
UI_CREATOR=MaintVerifyReadyDialog
[MaintCompleteDlg]
UI_CREATOR=MaintCompleteDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED
[MaintFailedDlg]
UI_CREATOR=MaintFailedDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED
[OemPreinstallLicenseDlg]
UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallProductInfoDlg]
#== This is from AEC - Revit, Civil 3D
[RevitContentPackDialog]
UI_CREATOR=ContentPackDialog
[AddAddonPage]
UI_CREATOR=AddAddonPage
[CADM_en-US]
DOWNLOAD_UNCOMPSIZE=12538294;15268278
DOWNLOAD_COMPSIZE=3513355;3813873
URL={FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/CADM_x86_en-US.tar.lzma2;{FCF7ABEC-BE59-406B-AB76-BFF1CFC2D2C4}/CADM_x64_en-US.tar.lzma2
[DOTNET45LANG_1025]
[DOTNET45LANG_1028]
[DOTNET45LANG_1029]
[DOTNET45LANG_1030]
[DOTNET45LANG_1031]
[DOTNET45LANG_1032]
[DOTNET45LANG_1035]
[DOTNET45LANG_1036]
[DOTNET45LANG_1037]
[DOTNET45LANG_1038]
[DOTNET45LANG_1040]
[DOTNET45LANG_1041]
[DOTNET45LANG_1042]
[DOTNET45LANG_1044]
[DOTNET45LANG_1045]
[DOTNET45LANG_1046]
[DOTNET45LANG_1049]
[DOTNET45LANG_1053]
[DOTNET45LANG_1055]
[DOTNET45LANG_2052]
[DOTNET45LANG_2070]
[DOTNET45LANG_3082]
1 REPLY 1
david.lau
in reply to: egbu3sg
We have a lot of people looking at this case.  The first thing is to setup a BROWSER download of the software.  This can be done via the Virtual Agent.  This is noted in Step 3 here:
http://upandready.typepad.com/up_and_ready/2013/01/quick-start-downloads.html
David Lau
Administrator Productivity
