Installation & Licensing
Revit License error 0.0.0 on opening
2 REPLIES 2
1360 Views, 2 Replies
We are unable to open Revit. When we attempt to open revit we receive the following error
Valid license could not be obtained by the network license manager. [0.0.0]
We are able to open other parts of the suite (autocad, autocad mechanical, etc).
Our license server is running on a windows 2008 r2 VM, the MAC address of the NIC on the VM matches the MAC address in the license.
When I go into LMTOOLS and perform a status enquiry, it spits out
Status
Flexible License Manager status on Thu 9/12/2013 10:53
[Detecting lmgrd processes...]
License server status:
27000@licserv
License file(s) on licserv: C:\Program Files\Autodesk\Autodesk Network License Manager\AUTODESK2014.lic:
licserv: license server UP (MASTER) v11.11
Vendor daemon status (on licserv):
adskflex: UP v11.11
Feature usage info:
Users of 86112EMS_2014_0F: (Total of 125 licenses issued; Total of 0 licenses in use)
results of licenseparser.com are
Configuration Information
Parsed License File AUTODESK2014.lic
License Type Single / Distributed
Computer / Hostname licserv
MAC Address / Host ID 000c295d419e
Specified Port First Available
Increments Matched
Seats 125
Feature Autodesk Education Master Suite 2014
Feature Code 86112EMS_2014_0F
Serial Number XXX-XXXXXXXX
Issue Date 24-Jul-2013
Expiration 23-jul-2016
Any help you can provide would be greatly appreciated!
Taylor Hammerling
MASD Network Engineer
Tags (3)
2 REPLIES 2
DarrenP
read this: http://upandready.typepad.com/up_and_ready/2013/07/education-master-suite-2014-revit-2014.html?utm_s...
DarrenP
dembkod
masdtaylor,
Hello. Yes, you need to ensure you have downloaded and installed the correct version of Revit first. If you have Revit installed and is still giving 0,0,0 errors, either your license file has been cut to only include an INCREMENT portion (no Package) or you are pointing to an old license manager that just does not have the license present.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
