I accidentally erased the direct access from mi laptop and now revit starts for a while and then stalls and a message to close the program apears. how can I repair this ? I already tried to reinstall and fix the program from autodesk but it doesn´t work still. what can I do next??.
Solved by benjaminb1. Go to Solution.
Have you tried doing a system restore back to when it worked?
I did a sistem restoration, and the program still not working , it opens somme of the files I just worked on , but don´t recognice the ones not open for a while.
