Installation & Licensing
New Member
caralinaj
Message 1 of 2 (718 Views)
Revit fails to install..
718 Views, 1 Replies
01-30-2013 02:38 PM
I have been searching in the internet but cannot find a error simmilar to my log fliles.. any help would be apperciated.
2013/1/30:13:31:21 Caralina CARALINA-HP === Setup started on CARALINA-HP by Caralina ===
2013/1/30:13:31:21 Caralina CARALINA-HP Launch
2013/1/30:13:31:21 Caralina CARALINA-HP Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2013/1/30:13:31:23 Caralina CARALINA-HP PageOpen LaunchDialog
2013/1/30:13:32:15 Caralina CARALINA-HP PageOpen LicenseDialog
2013/1/30:13:32:15 Caralina CARALINA-HP PageOpen ProductInfoDialog
2013/1/30:13:32:15 Caralina CARALINA-HP PageOpen ProductSelectionDialog2
2013/1/30:13:38:36 Caralina CARALINA-HP PageOpen FullProgressDialog
2013/1/30:13:38:36 Caralina CARALINA-HP Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2013/1/30:13:38:36 Caralina CARALINA-HP Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2013/1/30:13:40:21 Caralina CARALINA-HP Install DirectX® Runtime Succeeded
2013/1/30:13:40:21 Caralina CARALINA-HP Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2013/1/30:13:40:21 Caralina CARALINA-HP Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\Caralina\AppData\Local\Temp\FaroSDK.log"
2013/1/30:13:40:27 Caralina CARALINA-HP Install FaroSDK Succeeded
2013/1/30:13:40:27 Caralina CARALINA-HP Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2013/1/30:13:46:06 Caralina CARALINA-HP Download Error RVT2013 Decompressing failed http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2013/1/30:13:46:08 Caralina CARALINA-HP Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2013/1/30:13:46:08 Caralina CARALINA-HP Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603
2013/1/30:13:46:09 Caralina CARALINA-HP Rollback FaroSDK Failed Failure is ignored, Result=1619
2013/1/30:13:46:09 Caralina CARALINA-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
Employee
tony.michniewicz
Message 2 of 2 (683 Views)
Re: Revit fails to install..
02-01-2013 06:31 AM in reply to: caralinaj
Based upon the content of your log file, it appears that the download of Revit 2013 failed.  My recommendation would be to use the Download Now option, which includes a download manager that will help ensure a successful download of the Revit 2013 installer.
Tony Michniewicz
Autodesk Revit QA
