Installation & Licensing
Valued Contributor
17 Kudos
Post 1 of 11
Revit extensions 2013 HELP not found
585 Views, 10 Replies
12-19-2012 02:57 AM
When I click on help link in any of the Revit Extensions dialog boxes, I get the "file not found " error. How could I fix that?
File not found
Firefox can't find the file at /C:/Users/kasutaja/AppData/Roaming/Autodesk/REX/2013/DRevitModelsCompare/Help/en-US/files/GUID-2B7FD581-943C-4135-8589-75BC8AFB7A12.htm.
Check the file name for capitalization or other typing errors.
Check to see if the file was moved, renamed or deleted.
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Product Support
758 Kudos
Post 2 of 11
Re: Revit extensions 2013 HELP not found
12-20-2012 03:48 AM in reply to: Priitl220
Priitl,
Please check if the file exists in the indicated location. Tou may also try to change teh default internet browser.
I have checked this as Help opens with no problems (see teh atatched picture)
I can't see any problem copying the Help address to firefox either.
file:///C:/Users/user_name/AppData/Roaming/Autodesk/REX/2013/DRevitModelsCompare/Help/en-US/index.html?url=files/GUID-2B7FD581-943C-4135-8589-75BC8AFB7A12.htm,topicNumber=d30e20
Artur Kosakowski
Valued Contributor
17 Kudos
Post 3 of 11
12-20-2012 06:00 AM in reply to: Artur.Kosakowski
I have this help folder empty.
Others too.
REX\2013\DSynchAsdSteel\Help
REX\2013\DRevit2Robot\Help
REX\2013\DRevitModelsCompare\Help
Should I reinstall?
Product Support
758 Kudos
Post 4 of 11
12-20-2012 06:05 AM in reply to: Priitl220
Try to copy from the attached file.
Artur Kosakowski
Product Support
758 Kudos
Post 5 of 11
12-20-2012 06:06 AM in reply to: Priitl220
Artur Kosakowski
Product Support
758 Kudos
Post 6 of 11
12-20-2012 06:11 AM in reply to: Priitl220
Artur Kosakowski
Valued Contributor
17 Kudos
Post 7 of 11
12-20-2012 06:33 AM in reply to: Artur.Kosakowski
Thank you for your effort.
But there are more help files than those three. I  miss them all. I provided those folders as an example.
Why were they not installed?
Could you provide the whole help folder of rex?
Product Support
758 Kudos
Post 8 of 11
12-20-2012 06:49 AM in reply to: Priitl220
Some REX modules have got help files as chm files so they are not extracted to the folders. They are to be found in the REX folder itself
For the others the help file should be extracted (when you click on the HELP link) to the folders from zip files which can be found as shown below:
Artur Kosakowski
Valued Contributor
17 Kudos
Post 9 of 11
01-15-2013 06:07 PM in reply to: Artur.Kosakowski
I have this help folder empty. Others too. REX\2013\DSynchAsdSteel\Help REX\2013\DRevit2Robot\Help REX\2013\DRevitModelsCompare\Help Should I reinstall?
Product Support
758 Kudos
Post 10 of 11
01-16-2013 01:59 AM in reply to: Priitl220
Please check messages 4 to 6 where I attached these Help files. Please unpack them and navigate to Help\en-US\contexthelp folders. Then run the htm file with the corresponding module name.
Artur Kosakowski
