Installation & Licensing
Revit Architrecture 2012 Error 1603 and 1619
11 REPLIES 11
Message 1 of 12
lqtwil317
1099 Views, 11 Replies
I've tried installing this software about 5 times and everytime it has an error when installing the actual program.  It says Autodesk Revit Architecture 2012 Error 1603 and then everything after that fails with error 1619.  I've read through as many similar posts as I could find but none of the solutions worked.  I'm attaching my error log.
PLEASE HELP!!!
11 REPLIES 11
Message 2 of 12
DannyHubbard
in reply to: lqtwil317
Start with Travis's previous posting, http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 3 of 12
lqtwil317
If you read the install log you would see that all of the microsoft c++ programs installed just fine.  Before starting the install, i uninstalled all of the ones that were on the computer already.  The 1603 error occurs when it is installing the actual revit 2012 program, not its components.  The link you gave me doesn't even apply to my situation.  Please give me another suggestion but read my error log first.
Message 4 of 12
I checked your log file and your initial installation attempt failed because of a problem with the installation of Microsoft Visual C++ 2010 Redistributable (x86) but this pre-requisites is installed successfully in a later installation attempt.  At this point, I would recommend the following to ensure a clean installation of Revit Architecture 2012:
1. If Revit Architecture 2012 is included in the list of programs in the Programs and Features portion of Control Panel, try uninstalling it.  I doubt it will be listed but it is good to double check.
2. If they exist, delete the following folders:
C:\Program Files\Autodesk\Revit Architecture 2012
C:\ProgramData\Autodesk\RAC 2012
3. If they exist, delete the following registry keys:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\RAC 2012
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Revit\2012
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Revit\Autodesk Revit Architecture 2012
4. Delete any files and folders in C:\Windows\Temp as well as the Windows temp folder, which is accessible by navigating to %temp% in Windows Explorer.
5. Disable any virus scanners.
If you continue to encounter problems with this install, please post your latest log file.  It would also be good to know what operating system you are running and if there are any other Autodesk programs installed on this system.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Message 5 of 12
in reply to: Tony_Michniewicz
It did no work. I disabled BitDefender Anti Virus, had no folders you mentioned in my temp files. There's only one file, "Autodesk Sync" which I cannot uninstall. Any other suggestions are welcome. I did have a little trouble installing on Vista, but after 2x it was fine. I installed Windows 7 OS and this, like the first poster, is about the 4th time i've tried to install it. Any other suggestions?
Message 6 of 12
Tony_Michniewicz
Without an installation log file, it is difficult to identify why your Revit Architecture 2012 installation is failing.  Please delete the contents of your Windows temp folder, then try to install Revit Architecture 2012 once again.  When the installation fails, please make note of (or take a screen capture) the error that is generated.  Next, gather the install log file (if it is too large, create a zip file to reduce its size) and post it here for review.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Message 7 of 12
I did copy the log and a screen shot of the failure. Please refer to the
attached PDF.
FYI, I did follow the forum trail that went through a temp file deletion
process, but I will go through it again. Also, per other responses in forums
I don't understand why I Microsoft C++ Redistributable should be deleted
from my programs. If AutoDesk products do not talk to Microsoft programs,
that sounds like an AutoDesk programming issue. People who did uninstall
that program still unsuccessful were still unable to re-install. I will try
again, by emptying my temp folder. But please appreciate that 8 hours spent
trying time and time again to download a program represents some kind of
issue. Granted I may not be the computer genius that you are, but given that
I have solved many a computer issue without ever bothering anybody, replaced
my hard drive, etc - I think Autodesk should take a little more
responsibility.
Thank you.
Message 8 of 12
Tony_Michniewicz
Unfortunately I don't see an attachment to your last post so I don't have much information to go on.  If you don't have any other Autodesk programs installed on this system, my best suggestion would be to following the steps in the following technical solution, which should ensure that you have fully removed all Autodesk software from your computer:
http://usa.autodesk.com/getdoc/id=TS45252
If you do have other Autodesk programs installed, the steps I outlined in my previous post are still your best option.  Another option is to try Microsoft FixIt, which fixes problems with programs that can't be uninstalled properly.  This may help to alleviate the problem you are experiencing with the Autodesk Sync installation.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Message 9 of 12
Sorry you didn't get the attachments - I hit the reply link in the e-mail and attached them to the e-mail
Message 10 of 12
Tony_Michniewicz
Thanks for supplying your log file, which indicates that the installation is failing because of a problem during the installation of Microsoft Visual C++ 2010 Redistributable (x86).  Based on this, my next suggestion would be to try another installation of Revit Architecture 2012 but this time, disable the Design Review option and only install Revit Architecture and the Autodesk material library.  This configuration should allow you to avoid a Design Review install issue in which the installer fails when it finds a version of Microsoft Visual C++ that is newer than the one to be installed by Autodesk.
If the installation of Revit Architecture 2012 still fails when the Design Review option is disabled, another option would be to install the pre-requisites ahead of time.  I can point you to the individual installers if you need to try this approach.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Message 11 of 12
If anyone is still having this problem, I now know that it has to be dealt with very systematically because - maybe I'm slow, but my steps outlined below worked for me - Eureka! -
Tony, prior to receiving your last posting these were the steps I took.
  1. read nearly everyone elses post and went to posted links associated with this error
  2.  deleted every single .tmp file, one was locked - I don't know why because I am the administrator, it was w/ Bit Defender so I think it is okay
  3. I went to every nook and cranny that Autodesk downloads its files. I had a trial version of ACAD 2012 (prior to this multi attempt download of Revit) - so I got  rid of everything - I'm sure the majority on this site understands, that just uninstalling the program via the control panel doesn't mean all its tentacles are gone! Smiley Happy
  4. I took my last error log file and had it opened along side the control panel programs (Install/Uninstall). Everywhere the log had a failure after a Microsoft Visual C ++ file, I deleted that specific file.
  5. Shut down. Re-booted. Turned off all Anti-virus applications
So in the end even the even the Autodesk Design portion did instal!
It is simply unfortunate over the course of the past two days, I spent nearly 14 hours trying to resolve the issues. I hope the steps above help others too.
Thank you for your patience - I'm out of your hair!
Message 12 of 12
can you take a look at my issue? thank you
[SETUP]
SETUP_CODE={7346B4A0-1400-0500-0000-705C0D862004}
SETUP_ICON=SetupRes\Revit.ico
TITLE=\Autodesk Revit 2014
LOG=%tmp%\Autodesk Revit 2014 Setup.log
EVALMSI=SetupRes\eval.msi
PRIMARY_MSI=x86\RVT2014\RVT2014.msi
SYSUPDATE=MSI
RESOURCE_PATH=%lang%\SetupRes
LPMODE=NO_ADD_LP
DEFAULTMEDIALANGUAGE=en-US
DOCUMENT_LINK=Documentation\help-relay-page-online-revit.html
DOCUMENT_FALLBACK_LINK=Documentation\help-relay-page-offline-revit.html
SUPPORT_LINK=Documentation\readme-redirect-RVT.htm
SUPPORT_FALLBACK_LINK=Documentation\Readme\RVT Readme.htm
SYSTEMREQUIRE_LINK=Documentation\sysreq-redirect-revit.htm
SYSTEMREQUIRE_FALLBACK_LINK=Documentation\SysReq\autodesk_revit_product_line_system_requirements_and_recommendations_final.pdf
EULA_LINK=http://www.autodesk.com
INSTALL_PATH=%ProgramFiles%\Autodesk
CREATE_DESKTOP_SHORTCUT=YES
SETUP_HIGHLIGHT_COLOR=#9955AA
#==================== Platform Requirement
OSMAJVER=6
OSMINVER=0
SPMAJVER=0
#==================== Graphics Card Check
#OGS_XML_FILE=Setup\OgsTest.xml
#==================== Install Execute & UI Sequence
EXE_SEQUENCE=RVT2014;CMILM2014;NLM;CADM;REVITSERVER;SDK;ADDONS
INSTALL_SEQUENCE=NLM;CADM;REVITSERVER;RVT2014;CMILM2014;SDK;ADDONS
UI_SEQUENCE=LaunchDlg;BeginDeploymentDlg;LicenseDlg;ProductInfoDlg;ProductSelectionDlg2;RVT2014;CMILM2014;NLM;CADM;REVITSERVER;FullProgressDlg;InstallCompleteDlg;DeploymentCompleteDlg;DeploymentFailedDlg;ADDONS
#==================== UI
UI_MODE=
#==================== Deployment Info
DEPLOYMENT_NAME=
CLIENT_LOGGING=YES
EXTRA_FILES=REVIT;*.exe:eula:nlsdl:Setup:SetupRes:%lang%:3rdParty\MSI:Content
#==================== AdLM ProdKey Info
ADLM_CONFIG_FILE=Setup\RevitConfig.pit
ADLM_PIT_DLL=Setup\adlmPIT.dll
ADLM_VERSION=2014.0.0.F
ADLM_TRIAL_DAYS=30
#==================== Custom Callback
CB_FUNC=CustomCallbackRevitOSVersionCheck
CB_SOURCE=Setup\RevitSetup.dll
CB_PARAM=7.0.5730;7.0
CB_DESCRIPTION=Detecting Revit Supported Platforms
#==================== Global MSI Properties
PATH_LENGTH=149
[GLOBAL_MSI_PROPERTIES]
[MSI]
#== This is duplicated from [MSI4]
#== This is only needed if you list MSI in SYSUPDATE
PLATFORM=ALL
PRODUCT_NAME=Windows Installer Redistributable
EXE_PATH=3rdParty\MSI
EXE_PARAM=/quiet /norestart
VC_FUNC=MsiVerCheck
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=4.0
VC_DESCRIPTION=Detecting MSI
#==================== REVIT
[RVT2014]
PRODUCT_NAME=Autodesk® Revit® 2014
EXE_PATH=x86\RVT2014\RVT2014.msi
EXE64_PATH=x64\RVT2014\RVT2014.msi
LOG=%tmp%\Autodesk Revit 2014 Install.log
PRODUCT_MESSAGE=RevitSetupRes.dll;303
PLATFORM=NATIVE
ADMIN_INSTALL=NO
PREREQUISITE=RevitOSVersionCheck;IE7;SSE2;VCREDIST2008SP1X64;VCREDIST2008SP1X64_6161;VCREDIST2005X86;VCREDIST2005X64;VCREDIST2008SP1X86;VCREDIST2008SP1X86_6161;VCREDIST2010SP1X86;VCREDIST2010SP1X64;KB958314ATLX86;KB958314MFCX86;KB958314CRTX86;KB958314OPENMPX86;KB958314ATLX64;KB958314MFCX64;KB958314CRTX64;KB958314OPENMPX64;VCREDIST2005SP1ATLX86;VCREDIST2005SP1ATLX64;_DOTNET35SP1;DOTNET45;DOTNET45LANG;DIRECTX;FaroSDK;
#LS PREREQUISITE=
POSTREQUISITE=WORKFLOWS;CM2014;CMILB2014;CMILL2014
EXE_PARAM=
ACTION=INSTALL
REMOVE_PATH=
ROLLBACKABLE=YES
USE_EXTERNAL_UI=YES
UI_SEQUENCE=RevitShortcutPanel;RevitSettingsPage;DisciplinePage;UKResPage;RevitContentPackPanel;RevitConfigFolderPanel;AddAdditionalFilesPage;ServicePackPageForDeploy;ServicePackPageForInstall;InfoCenterCommCenterPage;OnlineResourcesPage;RevitServerAddressPanel
MAINTENANCE_UI_SEQUENCE=MaintenanceDlg;RevitContentPackDialog;RepairDlg;MaintVerifyReadyDlg;FullProgressDlg;MaintCompleteDlg;MaintFailedDlg
DISKCOST_FUNC=BSDGetDiskCost
DISKCOST_SOURCE=Setup\RevitContentPackUI.dll
INSTALL_FINALIZE=ContentPackFinalize
INSTALL_FINALIZE_SOURCE=Setup\RevitContentPackUI.dll
ALLOW_ADD_REMOVE=YES
EULA_PATH=eula
AVAILABLELANGUAGES=en-US
LPMODE=MUI
MUILPLINK=http://www.autodesk.com/revit-languagepacks
MSINEWINSTANCE=1
DEPLOYMENTLANGUAGE=en-US
DISK_PROMPT=RevitSetupRes.dll;107
DISK_LABEL=RVT2014
[RVT2014_LANGPACK]
PRODUCT_NAME=Autodesk® Revit® 2014 Language Pack
EXE_PATH=x86\%lang%\RVT2014\RVT2014LP.msi
EXE64_PATH=x64\%lang%\RVT2014\RVT2014LP.msi
ADMIN_INSTALL=NO
LOG=%tmp%\Autodesk Revit 2014 LangPack Install.log
[RVT2014_en-US]
DISK_LABEL=RVT2014
[RevitShortcutPanel]
UI_CREATOR=RevitShortcutPanel
UI_SOURCE=Setup\RevitSetup.dll
[RevitOSVersionCheck]
VC_FUNC=RevitOSVersionCheck
VC_SOURCE=Setup\RevitSetup.dll
VC_PARAM=7.0.5730;7.0
VC_DESCRIPTION=Detecting Revit Supported Platforms
#==================== REVIT Server
[REVITSERVER]
PLATFORM=x64
PRODUCT_NAME=Revit Server
PRODUCT_MESSAGE=RevitSetupRes.dll;503
PREREQUISITE=RevitServerOsVerCheck;DOTNET45;DOTNET45LANG
PRODUCT_GROUP=
EULA_PATH=eula
LOG=%tmp%\Autodesk Revit Server 2014 Install.log
EXE_PATH=%platform%\Tools\RS2014\RevitServer.msi
UI_SEQUENCE=RevitServerRolesPanel;RevitServerUsersPanel
INSTALL_TYPE=4
IGNORE_FAILURE=NO
[RevitServerAddressPanel]
UI_CREATOR=RevitServerAddressPanel
UI_CONDITION=ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[RevitServerRolesPanel]
UI_CREATOR=RevitServerRolesPanel
[RevitServerUsersPanel]
UI_CREATOR=RevitServerUsersPanel
[RevitServerOsVerCheck]
VC_FUNC=RevitServerOsVerCheck
VC_DESCRIPTION=Detecting Windows Server 2008
#==================== Modified Main Pages: Install Mode
[ADDONS]
INSTALL_TYPE=2
PRODUCT_NAME=\setupres.dll;189
PRODUCT_MESSAGE=SetupRes.dll;187
ACTION=INSTALL
UI_SEQUENCE=AddAddonPage
[LaunchDlg]
UI_CREATOR=LaunchDialog
UI_SOURCE=Setup\SetupAcadUi.dll
UI_CONSTRUCT_SOURCE=Setup\RevitContentPackUI.dll
UI_CONSTRUCT=cp_LaunchDlgConstruct
[ProductSelectionDlg2]
UI_CREATOR=ProductSelectionDialog2
UI_CONSTRUCT=SelectionDlgConstruct
UI_FINALIZE=RevitCreateCustomIni
UI_FINALIZE_SOURCE=Setup\RevitSetup.dll
#== The background image could change for you
[ProductInfoDlg]
UI_CREATOR=ProductInfoDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"TOOLS" AND NOT ADSK_OEMPREINSTALL
UI_FINALIZE=ContentNetCheck
UI_FINALIZE_SOURCE=Setup\RevitContentPackUI.dll
[FullProgressDlg]
UI_CREATOR=FullProgressDialog
UI_INFOTAINMENT_PATH=SetupRes\Infotainment\Images
UI_INFOTAINMENT_ELAPSE=18000
UI_CONSTRUCT_SOURCE=Setup\RevitSetup.dll
UI_CONSTRUCT=RevitDownloadContent
#================ Needed by REVIT =======================================================
[SDK]
PLATFORM=ALL
PRODUCT_NAME=Revit Software Development Kit
PRODUCT_GROUP=Supplemental Tools
EXE_PATH=Utilities\SDK\RevitSDK.exe
EXE_PARAM=-d"%SystemDrive%\Revit SDK 2014"
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
DISKCOST=300000000
[KB958314ATLX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\ATL\vc_atlx86runtime.msi
[KB958314MFCX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (MFC) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\MFC\vc_mfcx86runtime.msi
[KB958314CRTX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (CRT) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\CRT\vc_crtx86runtime.msi
[KB958314OPENMPX86]
PLATFORM=ALL
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)
EXE_PATH=3rdParty\x86\VCRedist\KB958314\OpenMP\vc_openmpx86runtime.msi
[KB958314ATLX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (ATL) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\ATL\vc_atlx64runtime.msi
[KB958314MFCX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (MFC) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\MFC\vc_mfcx64runtime.msi
[KB958314CRTX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (CRT) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\CRT\vc_crtx64runtime.msi
[KB958314OPENMPX64]
PLATFORM=x64
ADMIN_INSTALL=NO
PRODUCT_NAME=Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)
EXE64_PATH=3rdParty\x64\VCRedist\KB958314\OpenMP\vc_openmpx64runtime.msi
[IE7]
PRODUCT_NAME=Internet Explorer 7
PRODUCT_MESSAGE=SetupRes.dll;209
VC_FUNC=IeVerCheck
VC_DESCRIPTION=Detecting Internet Explorer 7
ACTION=INSTALL
EXE_PATH=NULL
#================================================= Autodesk tools ============================================================
[NLM]
PLATFORM=NATIVE
PRODUCT_NAME=Network License Manager
PRODUCT_MESSAGE=AcSetupRes.dll;47
LOG=%tmp%\NLM Install.log
EXE_PATH=%platform%\%lang%\Tools\NLM\NLM.msi
EXE_PARAM=ALLUSERS=1
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
DISKCOST=8000000
#== Add more available languages
LPMODE=MLD_ADR
EULA_PATH=EULA
[CADM]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk CAD Manager Tools
PRODUCT_MESSAGE=AcSetupRes.dll;46
PREREQUISITE=SSE2
LOG=%tmp%\CADManager Install.log
EXE_PATH=%platform%\%lang%\Tools\CADManager\CADManager.msi
INSTALL_TYPE=4
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
LPMODE=MLD_ADR
EULA_PATH=EULA
#================================================= 3rd Party tools ============================================================
[WORKFLOWS]
PLATFORM=NATIVE
PRODUCT_NAME=Autodesk Workflows 2014
LOG=%tmp%\Workflows 2014 Install.log
EXE_PATH=3rdParty\%platform%\Workflows\Workflow_%platform%.msi
ACTION=INSTALL
IGNORE_FAILURE=YES
ALLOW_ADD_REMOVE=NO
#================================================= Common Autodesk Content ============================================================
[CM2014]
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86
PRODUCT_NAME=Autodesk Material Library 2014
EXE_PATH=Content\ADSKMaterials\2014\CM\MaterialLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\CM\*.cab
ADMIN_INSTALL=NO
DISKCOST=88100000
EULA_PATH=eula
ACTION=INSTALL
[CMILB2014]
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86;CM2014
PRODUCT_NAME=Autodesk Material Library 2014 - Base Image Library
EXE_PATH=Content\ADSKMaterials\2014\ILB\BaseImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILB.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILB\*.cab
ADMIN_INSTALL=NO
DISKCOST=82900000
EULA_PATH=eula
ACTION=INSTALL
[CMILL2014]
PLATFORM=ALL
PRODUCT_NAME=Autodesk Material Library 2014 - Low Image Library
EXE_PATH=Content\ADSKMaterials\2014\ILL\LowImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILL.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILL\*.cab
ADMIN_INSTALL=NO
DISKCOST=258000000
EULA_PATH=eula
ACTION=INSTALL
[CMILM2014]
SHARED_COMPONENT=YES
PLATFORM=ALL
PREREQUISITE=VCREDIST2008SP1X86;CM2014;CMILB2014;CMILL2014
PRODUCT_NAME=Autodesk Material Library 2014 - Medium Image Library
PRODUCT_MESSAGE=AcSetupRes.dll;61
EXE_PATH=Content\ADSKMaterials\2014\ILM\MediumImageLibrary2014.msi
LOG=%tmp%\MaterialLibrary2014CMILM.log
EXTRA_FILES=acad;Content\ADSKMaterials\2014\ILM\*.cab
ROLLBACKABLE=YES
ALLOW_ADD_REMOVE=NO
ADMIN_INSTALL=NO
DISKCOST=762000000
EULA_PATH=eula
#== Uncomment the line below if you want it installed by default
ACTION=INSTALL
#================================================= Common Autodesk Components ============================================================
#================================================= 3rd Party Components ============================================================
#== Note about 3rdParty licenses:
#== If 3rdParty component licenses need to be included in the media, put them in 3rdParty\Licenses folder.
#== Taking the example of Revit Architecture:
#== RAC2012\3rdParty\Licenses\
#== - GNU
#== - Mozilla Public License
#== You may be required to ship the source code to the 3rd party components, for example QT (free license).
#== Put the source code in the 3rdParty\Source\[ComponentName{VerX.X}] folder. You must add a version number to the component so it does not conflict with other products.
#== For example:
#== RAC2012\3rdParty\Source\QT5.5\
[MSI4]
PLATFORM=ALL
VC_FUNC=MsiVerCheck
VC_PARAM=4.0
[NLSDL]
PLATFORM=NATIVE
PRODUCT_NAME=Microsoft NLS Downlevel APIs
EXE_PATH=NLSDL\nlsdl.x86.exe
EXE64_PATH=NLSDL\nlsdl.amd64.exe
IGNORE_FAILURE=YES
#============= VCREDIST Begin ===============
#== Note about VCREDIST section names used:
#== The template uses a naming that matches the MSDN download name. It doesn’t use a version number.
#== For example, if you downloaded the package from http://www.microsoft.com/downloads/en/details.aspx?familyid=a5c84275-3b97-4ab7-a40d-3802b2af5fc2&dis...
#== you would use [VCREDIST2008SP1X86] in the INI.
[VCREDIST2010SP1X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe
EXE_PARAM=/q /norestart
VC_FUNC=VCx86RedisCheck
VC_PARAM={F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}
IGNORE_ERROR=5100
[VCREDIST2010SP1X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2010 SP1 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe
VC_FUNC=VCx64RedisCheck
VC_PARAM={1D8E6291-B0D5-35EC-8441-6616F567A0F7}
IGNORE_ERROR=5100
[VCREDIST2008SP1X86_6161]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161
EXE_PATH=3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={9BE518E6-ECC6-35A9-88E4-87755C07200F}
[VCREDIST2008SP1X64_6161]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}
PLATFORM=ALL
EXE_PATH=3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={1F1C2DFC-2D24-3E06-BCB8-725134ADF989}
[VCREDIST2008SP1X64]
PLATFORM=x64
EXE64_PATH=3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe
EXE_PARAM=/q
ROLLBACKABLE=NO
IGNORE_ERROR=YES
VC_PARAM={4B6C7001-C7D6-3710-913E-5BC23FCE91E6}
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x86_2005.log"" "
VC_PARAM={837b34e3-7c30-493c-8f6a-2b0f04e2912c}
[VCREDIST2005SP1ATLX64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe
EXE_PARAM=/q:a /T:%windir%\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v %temp%\vcredist_x64_2005.log"" "
VC_PARAM={6ce5bae9-d3ca-4b99-891a-1dc6c118a5fc}
[VCREDIST2005X86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005\vcredist_x86.exe
VC_PARAM={7299052B-02A4-4627-81F2-1818DA5D550D}
[VCREDIST2005X64]
PLATFORM=x64
PRODUCT_NAME=Microsoft Visual C++ 2005 Redistributable (x64)
EXE64_PATH=3rdParty\x64\VCRedist\2005\vcredist_x64.exe
VC_PARAM={071C9B48-7C32-4621-A0AC-3F809523288F}
#============= VCREDIST End ===============
[SSE2]
PRODUCT_NAME=SSE2 Support Check
PRODUCT_MESSAGE=SSE2 Support Check
EXE_PATH=NULL
VC_FUNC=CheckForSSE2Support
VC_DESCRIPTION=SSE2 Support Check
#============= DOTNET Begin ===============
[DOTNET45]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe
VC_FUNC=DotnetVerify
VC_PARAM=.NET Framework 4.5
VC_DESCRIPTION=Detecting .NET 4.5 Runtime
DISKCOST=816640000
[DOTNET45LANG]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5 Language pack
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotNetFx45LP_Full_x86_x64_%lcid%.exe
AVAILABLELANGUAGES=1025;1028;1029;1030;1031;1032;1035;1036;1037;1038;1040;1041;1042;1044;1045;1046;1049;1053;1055;2052;2070;3082
VC_FUNC=DotnetLangPacksVerCheck
VC_PARAM=%lcid%;4.5.50709
LPMODE=MLD_ADR
IGNORE_LANGS=1033
IGNORE_FAILURE=YES
DISKCOST=3000000
[_DOTNET35SP1]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 3.5 SP1
EXE_PATH=3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe
VC_PARAM=.NET Framework 3.5 SP1
VC_DESCRIPTION=Detecting .NET Runtime 3.5 SP1
DISKCOST=80000000
IGNORE_FAILURE=NO
#============= DOTNET End ===============
[DIRECTX]
PLATFORM=ALL
PREREQUISITE=_DOTNET35SP1
PRODUCT_NAME=DirectX® Runtime
EXE_PATH=3rdParty\DirectX\DXSETUP.exe
EXE_PARAM=/silent
IGNORE_FAILURE=YES
DISKCOST=50000000
[FaroSDK]
PLATFORM=NATIVE
PRODUCT_NAME=FaroSDK
EXE_PATH=3rdParty\%platform%\FaroSDK\FARO.LS_5.1.0.30630.msi
LOG="%tmp%\FaroSDK.log"
ACTION=INSTALL
IGNORE_FAILURE=YES
#==================== Common Main Pages: Install Mode
[LicenseDlg]
UI_CREATOR=LicenseDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL
[InstallCompleteDlg]
UI_CREATOR=InstallCompleteDialog
UI_CONDITION=ADSK_LAUNCH_MODE<>"DEPLOYMENT" AND ADSK_LAUNCH_MODE<>"MINIMAL_DEPLOYMENT"
#==================== Common Main Pages: Deploy Mode
[BeginDeploymentDlg]
UI_CREATOR=BeginDeploymentDialog
UI_SOURCE=Setup\DeployUi.dll
[DeploymentCompleteDlg]
UI_CREATOR=DeploymentCompleteDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND ADSK_SETUP_SUCCEEDED
[DeploymentFailedDlg]
UI_CREATOR=DeploymentFailedDialog
UI_CONDITION=(ADSK_LAUNCH_MODE="DEPLOYMENT" OR ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT") AND NOT ADSK_SETUP_SUCCEEDED
#==================== Common Config pages: Install Mode
[InstallTypePage]
UI_CREATOR=InstallTypePage
[RevitContentPackPanel]
UI_CREATOR=ContentPackPage
UI_SOURCE=Setup\RevitContentPackUI.dll
[RevitConfigFolderPanel]
UI_CREATOR=ConfigFolderPage
[DisciplinePage]
UI_CREATOR=RevitDisciplinePanel
[UKResPage]
UI_CREATOR=RevitUKResPanel
#==================== Common Config Pages: Deploy Mode
[ContentLocationPage]
UI_CREATOR=ContentLocationPage
[PathCustomizationPage]
UI_CREATOR=PathCustomizationPage
[AddAdditionalFilesPage]
UI_CREATOR=AddAdditionalFilesPage
[WorkstationSettingPage]
UI_CREATOR=WorkstationSettingPage
[ServicePackPageForDeploy]
UI_CREATOR=ServicePackPage
[ServicePackPageForInstall]
UI_CONDITION=ADSK_RUNNING_FROM_ADMIN="FALSE" AND NOT ADSK_LAUNCH_MODE="DEPLOYMENT" AND NOT ADSK_LAUNCH_MODE="MINIMAL_DEPLOYMENT"
[InfoCenterCommCenterPage]
UI_CREATOR=InfoCenterCommCenterPage
[OnlineResourcesPage]
UI_CREATOR=OnlineResourcesPage
UI_POSTCONSTRUCT_SOURCE=Setup\RevitSetup.dll
UI_POSTCONSTRUCT=OnlineResourcesPostConstruct
[RevitSettingsPage]
UI_CREATOR=RevitSettingsPanel
#==================== Common Main Pages: Maintenance Mode
[MaintenanceDlg]
UI_CREATOR=MaintenanceDialog
[AddRemoveFeaturesDlg]
UI_CREATOR=AddRemoveFeaturesDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT REINSTALL="ALL" AND NOT REMOVE="ALL"
[RepairDlg]
UI_CREATOR=RepairDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND REINSTALL="ALL"
[MaintVerifyReadyDlg]
UI_CREATOR=MaintVerifyReadyDialog
[MaintCompleteDlg]
UI_CREATOR=MaintCompleteDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND ADSK_SETUP_SUCCEEDED
[MaintFailedDlg]
UI_CREATOR=MaintFailedDialog
UI_CONDITION=NOT ADSK_OEMPREINSTALL AND NOT ADSK_SETUP_SUCCEEDED
[OemPreinstallLicenseDlg]
UI_CONDITION=ADSK_OEMPREINSTALL="1"
[OemPreinstallProductInfoDlg]
#== This is from AEC - Revit, Civil 3D
[RevitContentPackDialog]
UI_CREATOR=ContentPackDialog
[AddAddonPage]
UI_CREATOR=AddAddonPage
Administrator Productivity
