Installation & Licensing
Revit architecture will not install
14 REPLIES 14
Message 1 of 15
choicefotos.perth
520 Views, 14 Replies
I have tried twice to install Revit I am totally confused
It comes up stating some products have not installed.
attached is the installation log, my system requirements are correct etc
14 REPLIES 14
Message 2 of 15
My system I am running
64bit windows 8
I also have installed auto CAD 2d also solid works
Message 3 of 15
Revit 2012 is not supported on Windows 8, http://usa.autodesk.com/getdoc/id=TS14026408, but you might try Travis's previous post http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-....
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 4 of 15
Actually, your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again. Uninstall the version that shows the error at the end of your log file.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Autodesk Forums:
Message 5 of 15
could you give me a hint on what i need to uninstall and then reinstall
Message 6 of 15
Microsoft Visual C++ 2010 Redistributable (x86)
 Uninstall that from Control Panel.  Then run the Autodesk installer.  Let it try to install it.  If it fails, install it manually from Microsoft and see if that helps.
Autodesk Forums:
Message 7 of 15
thanks I will give it a go
Message 8 of 15
in reply to: choicefotos.perth
I am having the same problem and will try uninstalling the Microsoft Visual C++ 2010 as you suggested.  Will I need to reinstall that after Revit successfully installs (I hope)?
Message 9 of 15
choicefotos.perth
It defiantly worked for me good luck
Message 10 of 15
OK, so you uninstalled the Microsoft Visual program, then ran the Autodesk Revit install again? Do we need the Visual Programafter that?
Message 11 of 15
in reply to: TravisNave
I am having the same problem as choicefotos.perth.  Your suggestion was successful for them.  My question is, do we need the Microsoft Visual program after Revit installs successfully?  If so, where do we find that again?  My installation log file is attached.
Message 12 of 15
choicefotos.perth
Im not sure I think revit reinstalled it
Message 13 of 15
OK, I will give it a try. Thanks.
Message 14 of 15
I have tried uninstalling the MicroSoft Visual C++ 2010 and the MicroSoft Visual C++ 2005 programs, with no success.  Do you have any other suggestions as to what I can try?  I have attached the most recent installation log.
Message 15 of 15
TravisNave
Your problem is with C++ 2008.  You can try installing it manually from Microsoft.com if you need to.  Or see my link here:
Good Luck!
Autodesk Forums:
Administrator Productivity
