Installation & Licensing
Active Member
0 Kudos
Post 1 of 15
Revit architecture will not install
246 Views, 14 Replies
03-26-2013 06:19 AM
I have tried twice to install Revit I am totally confused
It comes up stating some products have not installed.
attached is the installation log, my system requirements are correct etc
Active Member
0 Kudos
Post 2 of 15
Re: Revit architecture will not install
03-26-2013 06:21 AM in reply to: choicefotos.perth
My system I am running
64bit windows 8
I also have installed auto CAD 2d also solid works
Employee
62 Kudos
Post 3 of 15
03-27-2013 06:44 AM in reply to: choicefotos.perth
Revit 2012 is not supported on Windows 8, http://usa.autodesk.com/getdoc/id=TS14026408, but you might try Travis's previous post http://forums.autodesk.com/t5/Installation-Licensing/AutoCAD-2013-Suite-failed-installation-aborted-....
Danny
Danny Hubbard
QA Analyst
893 Kudos
Post 4 of 15
03-27-2013 08:01 AM in reply to: choicefotos.perth
Actually, your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again. Uninstall the version that shows the error at the end of your log file.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Good Luck!
Active Member
0 Kudos
Post 5 of 15
03-27-2013 08:21 AM in reply to: TravisNave
could you give me a hint on what i need to uninstall and then reinstall
893 Kudos
Post 6 of 15
03-27-2013 08:29 AM in reply to: choicefotos.perth
Microsoft Visual C++ 2010 Redistributable (x86)
 Uninstall that from Control Panel.  Then run the Autodesk installer.  Let it try to install it.  If it fails, install it manually from Microsoft and see if that helps.
Active Member
0 Kudos
Post 7 of 15
03-27-2013 08:35 AM in reply to: TravisNave
thanks I will give it a go
Active Member
0 Kudos
Post 8 of 15
03-27-2013 06:44 PM in reply to: choicefotos.perth
I am having the same problem and will try uninstalling the Microsoft Visual C++ 2010 as you suggested.  Will I need to reinstall that after Revit successfully installs (I hope)?
Active Member
0 Kudos
Post 9 of 15
03-27-2013 06:50 PM in reply to: bethannt31
It defiantly worked for me good luck
Active Member
0 Kudos
Post 10 of 15
03-27-2013 06:53 PM in reply to: choicefotos.perth
OK, so you uninstalled the Microsoft Visual program, then ran the Autodesk Revit install again? Do we need the Visual Programafter that?
