Installation & Licensing
Revit Architecture Suite 2010 crashing upon launch
3 REPLIES 3
tedaburn
506 Views, 3 Replies
Just started today, and am completely unable to use.
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             Revit.exe
  Application Version:                           2010.0.2009.917
  Application Timestamp:                     4ab3ad5f
  Fault Module Name:                          StackHash_621d
  Fault Module Version:                        0.0.0.0
  Fault Module Timestamp:                  00000000
  Exception Code:                                  c0000005
  Exception Offset:                                16b93a90
  OS Version:                                          6.1.7600.2.0.0.256.48
  Locale ID:                                             1033
  Additional Information 1:                  621d
  Additional Information 2:                  621d0e4efe54ee6215ceff398d8267db
  Additional Information 3:                  639c
  Additional Information 4:  639c8c6187e610e618cd70fae983fd0a
3 REPLIES 3
TravisNave
in reply to: tedaburn
If it just started today, try doing a system restore to yesterday or earlier in the week before the problem started.  Might be worth a shot.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
tedaburn
in reply to: TravisNave
Unfortunately not an option...
I've even tried reinstalling and repairing. Didn't help. I am looking into doing a "clean" install and see if that helps.
TravisNave
That might be your best choice then at this time.
Autodesk Forums:
Administrator Productivity
