During Network Deployment, the installer keeps running msiexec.exe long after the installation reports back as finished. The reason this is a problem is because I am unable to run or replace the revit.exe that needs to be replaced in order to use our licensing software.
I know it was msiexec.exe because I used procmon to see what was using revit.exe(accessed some 4000 times btw, during install)
Has anyone else ran into this problem?
