I have installed Revit Architecture 2015, when I try to activate it gave me an error code 110? Installed stand-alone, entered correct SN and Product Key. Not working! Uninstalled completely, rebooted workstation, Installed and still get error when trying to activate.
Solved by MS_jkimc65. Go to Solution.
Hello and welcome to the Autodesk Community!
For licensing assistance and to obtain an activation code, please visit our Virtual Agent. If the activation code generation fails for any reason, a case will be automatically generated and sent to the Activation and Registration team for resolution.
Please let me know if you have any other questions or concerns. Thank you!
Jessica,
Thanks for the reply and the additional information, on your second posting, my Autodesk Reseller tried that same solution as what was posted by nachanok_rim. My Autodesk Reseller is Bryson Anderson of ProSoft. I didn't get a case number from him. I've included his contact info if you would like to follow up with him. I have not heard from him since yesterday when he needed my serial number and the productinformation.pit file. I sent that info to him earlier this morning.
Thanks Again,
J. Kim Candelario
It sounds like your representative is on the right track, but if you need further assistance be sure to let us know. Thank you!
Jessica,
So, the mistake I did was installing a standalone Revit 2015 rather than installating the Building Design Suite Premium with the serial number coinciding with the BDSP. Installation of the single license is for our office laptops. This was an oversight on my part. All is well and running Revit 2015! Thanks to my Autodesk Reseller for assisting in getting this issue resloved! This can be closed out.
No worries, we're happy as long as you're up and running! Thanks for the follow up and have a nice weekend!
hi i have installed revit 2015 it says installed successfully but no Revit icon on the desktop or no application icon on the control panel any solution please
