Installation & Licensing
Revit Architecture 2014 Failed Install 1619
21 REPLIES 21
Message 1 of 22
hrm3
4648 Views, 21 Replies
I have tried this Revit Arch 2014 deployment on several machines with similar results.  (all have Revit 2012 installed which much remain)  below is the error log.  Please assist.  Thank you.
2013/6/6:15:47:27 HRM NCR-LAPTOP === Setup started on NCR-LAPTOP by HRM ===
2013/6/6:15:47:27 HRM NCR-LAPTOP Path_Length: 149
2013/6/6:15:47:27 HRM NCR-LAPTOP Current Directory \\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img
2013/6/6:15:47:27 HRM NCR-LAPTOP Launch
2013/6/6:15:47:27 HRM NCR-LAPTOP CommandLine /qb /I \\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\Revit2014.ini /language en-us
2013/6/6:15:47:27 HRM NCR-LAPTOP Current Directory C:\Users\hrm\AppData\Local\Temp\_AI2EDC.tmp
2013/6/6:15:47:40 HRM NCR-LAPTOP === Setup ended ===
2013/6/6:15:47:34 HRM NCR-LAPTOP === Setup started on NCR-LAPTOP by HRM ===
2013/6/6:15:47:34 HRM NCR-LAPTOP Path_Length: 149
2013/6/6:15:47:34 HRM NCR-LAPTOP Current Directory C:\Users\hrm\AppData\Local\Temp\_AI2EDC.tmp
2013/6/6:15:47:34 HRM NCR-LAPTOP Launch
2013/6/6:15:47:34 HRM NCR-LAPTOP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\hrm\AppData\Local\Temp\_AI2EDC.tmp\Setup\RevitSetup.dll
2013/6/6:15:47:34 HRM NCR-LAPTOP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/6/6:15:47:40 HRM NCR-LAPTOP Installing Microsoft Visual C++ 2005 Redistributable (x86): "\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\hrm\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/6/6:15:47:51 HRM NCR-LAPTOP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/6/6:15:47:51 HRM NCR-LAPTOP Installing DirectX® Runtime: "\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2013/6/6:15:48:08 HRM NCR-LAPTOP Install DirectX® Runtime Succeeded
2013/6/6:15:48:08 HRM NCR-LAPTOP Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit Architecture 2014" SETUP_PACKAGECODE={7346B4A0-1400-0100-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/6/6:15:48:29 HRM NCR-LAPTOP Install FaroSDK Succeeded
2013/6/6:15:48:29 HRM NCR-LAPTOP Installing Autodesk® Revit® Architecture 2014: TRANSFORMS="\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\x64\en-us\RAC2014\RAC2014.mst;\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\x64\RAC2014\RAC2014-Revit2014.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit Architecture 2014" SETUP_PACKAGECODE={7346B4A0-1400-0100-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=",Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2005 Redistributable (x86),Microsoft Visual C++ 2005 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,DirectX® Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},;{11672AB2-3D48-4D38-9123-719E5FF93333},{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{5C29CC1F-218F-4C30-948A-11066CAC59FB},;;" ADSK_SOURCE_ROOT="\\GWWO7\PCSetup\Autodesk\Deployments\RAC 2014\Img\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/6/6:15:48:33 HRM NCR-LAPTOP Install Autodesk® Revit® Architecture 2014 Failed Installation aborted, Result=1603
2013/6/6:15:48:36 HRM NCR-LAPTOP Rollback FaroSDK Succeeded
2013/6/6:15:48:37 HRM NCR-LAPTOP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/6/6:15:48:37 HRM NCR-LAPTOP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/6/6:15:48:40 HRM NCR-LAPTOP === Setup ended ===
21 REPLIES 21
Message 21 of 22
Darin.Green
in reply to: hrm3
Good to hear everything worked out for you... Just remember for future reference to use UNC pathing without any spaces in the path. Smiley Happy
Have a good day!
Also, please mark this thread as resolved.
If this information was helpful, please consider using the Accept Solution
Message 22 of 22
amitwhig
in reply to: Darin.Green
Dear Sir / AutoDesk
Can you please apprise what shall be the problem in installing Revit Architecture 201 on my system
I am attaching a screenshot.
Pls Help. (My system is windows 8 with Pentium i& 3630 2.4 GHz, 12 GB DDR3 and 1 TB HDD)
I am trying to install from my Hard Disk.
Rgds
Administrator Productivity
