Installation & Licensing
New Member
james.bender
Message 1 of 7 (670 Views)
REVIT Architecture 2014 - Cannot get license
670 Views, 6 Replies
07-17-2013 08:44 AM
We've got a single license manager server, and have activated keys for the EMS_2014 Suite installed.
"86112EMS_2014_0F" v1.000, vendor: adskflex
  License server: e143autocadlm
  floating license  starts: 1-jan-1990,   expires: 15-jul-2016
  Requests from the same USER/HOST do not consume a new license
This license can be checked out
Users of 86112EMS_2014_0F:  (Total of 125 licenses issued;  Total of 0 licenses in use)
AutoCAD 2014 Runs and gets licenses from it
Inventor 2013 Runs and gets licenses from it
Revit Architecture 2014 gives an error of 0.0.0 no license obtained.
We've tried Revit Architecture 2014 with the product code of 240F1 and 241F1 both do the same thing.  Where do I go from here?
DarrenP
Message 2 of 7 (668 Views)
Re: REVIT Architecture 2014 - Cannot get license
07-17-2013 08:59 AM in reply to: james.bender
according to this http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21379174&linkID=9242018&CMP=OTC-RSS...
revit architecture 2014 doesn't grab an  Education Master Suite 2014 license only revit one box does
New Member
lcsdhelpdesk
Message 3 of 7 (655 Views)
07-17-2013 11:03 AM in reply to: DarrenP
Having the same issue.  Is everyone having this issue rolling back to 2013 and getting a 2013 license?
New Member
james.bender
Message 4 of 7 (652 Views)
07-17-2013 11:14 AM in reply to: DarrenP
Well here is the problem though, for licenses we have the following.
Autodesk 3ds Max Design 2014 (English) 64-Bit
Autodesk AutoCAD 2014 (English) 32-Bit
Autodesk AutoCAD 2014 (English) 64-Bit
Autodesk AutoCAD Architecture 2014 (English) 32-Bit
Autodesk AutoCAD Architecture 2014 (English) 64-Bit
Autodesk AutoCAD Civil 3D 2014 (English) 64-Bit
Autodesk AutoCAD Mechanical 2014 (English) 32-Bit
Autodesk AutoCAD Mechanical 2014 (English) 64-Bit
Autodesk InfraWorks 2014 (English) 64-Bit
Autodesk Inventor Professional 2014 (English) 32-Bit
Autodesk Inventor Professional 2014 (English) 64-Bit
Autodesk Revit Architecture 2014 (English) 32/64-Bit
Autodesk Showcase 2014 (English) 32-Bit
Autodesk Showcase 2014 (English) 64-Bit
xxx-xxxxxx 125
So what product code should I be using to get that version of Revit to run?  It is supposed to be part of the Education Master Suite we have.
DarrenP
Message 5 of 7 (643 Views)
07-17-2013 11:46 AM in reply to: james.bender
it could be a bug with the Educational Master Suite 2014
i would contact your educational license supplier and have them create a case with autodesk
dtiemeyer
Message 6 of 7 (636 Views)
07-17-2013 12:28 PM in reply to: DarrenP
Also, for some of the products with 'cascading' licensing, the order in which the license file is sequenced is important. Try putting your 'most valuable' products (e.g. Revit) at the beginning.
See an earlier post of mine for reference:
http://forums.autodesk.com/t5/Installation-Licensing/Cascading-Licenses-AMEP-and-Revit-Systems-Serie...
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
DarrenP
Message 7 of 7 (568 Views)
07-26-2013 09:43 AM in reply to: dtiemeyer
