Installation & Licensing
Active Contributor
martysaid2009
Message 11 of 36 (6,358 Views)
Re: Revit Architecture 2013 Missing Families on Install
07-08-2012 04:50 PM in reply to: roohullah.09ar01.muet
Thanks for the reply roohullah.
Marty Said
Revit Architecture 2014
Member
ranced
Message 12 of 36 (4,880 Views)
02-11-2013 12:50 PM in reply to: TrendyGuy
Hi guy right I have copy the family and templates from a working autodesk revit 2013 this is from my desktop machine
the copies are from the student edd but that shouldnt be a problem
bellow is the dropbox account link for the files
https://www.dropbox.com/sh/d3du2kcevn8lur5/p0p0He9UfU?m
download - ZIPfile
follow instructions txt file
New Member
jchlopek7886
Message 13 of 36 (4,654 Views)
03-06-2013 11:32 AM in reply to: DannyHubbard
I have the same problem missing families from the libraries
But your solution did not work the same material is still missing
Member
Message 14 of 36 (4,617 Views)
03-08-2013 07:14 AM in reply to: jchlopek7886
Trun off firewall before installing the revit 2013. It worked for me
New Member
jchlopek7886
Message 15 of 36 (4,607 Views)
03-08-2013 11:41 AM in reply to: TrendyGuy
I have to say that these "solutions" are not helping.
Can you send the appropriate files to me?
The program is working fine otherwise but I have to travel to my school just to insert a door in a curtain wall.
are there no tech support people who can actually speak to me?
Jchlopek
Member
priscilabonifacio
Message 16 of 36 (4,457 Views)
03-14-2013 10:23 PM in reply to: martysaid2009
I turned off my firewall, restarted my PC and I could Add the Brazils Metric Library. How ever, besides the US Metrical/Imperial were on the Features List, their folders remain EMPTY! My lucky is that at least I have a library now.
But Autodesk should NOT forget about those mistakes!!!!! And at LEAST what Autodesk could do is provide the Library Folders for us to download, because some people just might not have the problem fixed!!!!
Or launch an update that fix this stuff. Very soon Ill be changing my PC and I wouldnt like to go through this all over again...
Member
ranced
Message 17 of 36 (4,352 Views)
03-21-2013 08:56 AM in reply to: priscilabonifacio
you need to make sure all the folders are in the correct location easyest way to do so is to make sure templates are located in the directories this is the RAC folder if the library is missing revit will promt that is missing copy from dropbox into folder that revit opens direct too ============================================ The LSBU communications disclaimer can be found at http://www.lsbu.ac.uk/ict/legal/
New Member
mrs.jordan.92
Message 18 of 36 (4,307 Views)
03-24-2013 12:43 PM in reply to: TrendyGuy
hellooo life savers ,,
that's driving me crazy ! i tried everything and i still in the same prob. even i got the families from my friend, and i have them on my desktop ! and every time i want to add a door or window or anything i have to load it ! and the families that i load do not stay saved ! every time i have to do the same,, and btw i installed the prog. 4 times :\\ and tried 2010vre. 2011ver 2012ver & now i have 2013..
any HELP :smileysad:
thnk u
Member
ranced
Message 19 of 36 (4,238 Views)
03-30-2013 08:49 AM in reply to: mrs.jordan.92
you cant have the files on your desktop they have to be in the designated location Autodesk give but if are having problems find this location you can all way load from components into the project if you have problems with this let me know asap ============================================ The LSBU communications disclaimer can be found at http://www.lsbu.ac.uk/ict/legal/
Member
shazeb_rockz
Message 20 of 36 (3,585 Views)
07-11-2013 01:11 AM in reply to: DannyHubbard
i disabled firewall and antivirus yet no result.....
i have almost unistalled and reinstalled it 7-8 times evn offline and using internet
infact when i install revit 2013 no folder named RAC is created....
please help
i am in veryyyyyyyy urgent need to design using revit and there is no families to load doors windows etc.....
pleaseeeee help needed urgent
