Installation & Licensing
New Member
ccarpenterhchs
Message 1 of 18 (2,774 Views)
*Revit Architecture 2012 Installation Problems
2774 Views, 17 Replies
03-22-2012 01:26 PM
I ran the installation that I downloaded from the Students part of the site. The install goes as far as putting in the product code, after that it gives an error. (refer to the attachments)
Someone help me out? I can give my computer specs and other things, just reply.
Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
You need to uninstall your Visual C++ from Control Panel > Programs and then run your installer again.
TravisNave
Message 2 of 18 (2,771 Views)
Re: *Revit Architecture 2012 Installation Problems
03-22-2012 01:28 PM in reply to: ccarpenterhchs
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
fzunit
Message 3 of 18 (2,544 Views)
05-19-2012 11:14 PM in reply to: ccarpenterhchs
thanx alot sorry do i have to uninstall all c++?
TravisNave
Message 4 of 18 (2,531 Views)
05-21-2012 07:41 AM in reply to: fzunit
Start with just the 2010 versions.  If you get failures for others, then do the same.  You should be fine as this is a common issue.  The Autodesk installer and Windows Update will put back the versions after you remove them, so there's not a lot ot be worried about.
Member
10779706
Message 5 of 18 (2,339 Views)
08-27-2012 08:28 PM in reply to: ccarpenterhchs
i have uninstalled almost all of my visual c++ programs and i am still having problems with my install of revit architecture 2012. what should be the next step because i am a student and my school just upgraded and i need the program up and running asap. i am attatching my log file to help with diagnostics. thank you for your time and assistance and hope to hear from you soon.
TravisNave
Message 6 of 18 (2,303 Views)
08-28-2012 08:25 AM in reply to: 10779706
Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
Make sure you don't have any C++ 2005.  If it still fails, seeif you can perform the necessary update manually from Microsoft before you install.
Member
10779706
Message 7 of 18 (2,297 Views)
08-28-2012 10:47 AM in reply to: ccarpenterhchs
i manually installed from windows update and windows update keeps asking to download the same file over and over. i have tried removing all of my c++ 05, 08, & 10 seperately and all together and i am still having the same results. i am restarting between uninstallations/installations of c++ and nothing still getting error code 1603 for Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) but i have it downloaded several times (see attatchments).
Member
10779706
Message 8 of 18 (2,294 Views)
08-28-2012 10:51 AM in reply to: 10779706
TravisNave
Message 9 of 18 (2,290 Views)
08-28-2012 11:01 AM in reply to: 10779706
Okay, well remove all the 2005 instances and do not replace them.  Run the Autodesk installer and let it install the versions it wants.
Member
jlove135
Message 10 of 18 (1,560 Views)
06-18-2013 08:23 PM in reply to: TravisNave
Can you possibly help with my problem upon opening the install file it gets to the end and says some files can not be created and says to close all application and restart my computer i do this and start again and it says the same thing
