Installation & Licensing
*Revit Architecture 2012 Installation Problems - student version
1 REPLY 1
197 Views, 1 Reply
Since I only needed to install the 64 bit CD's, everything was fine, until I came to the very last of the 3 CD's (Autodesk Revit Architecture 2012). The last screen of the install stated that the install was complete but some products failed to install. The 3 products that didn't install were 'Autodesk Revit Architecture 2012', 'Autodesk Design Review 2012', and 'Autodesk Material Library 2012 - Medium Image Library'. There's a red X, next to all three but also the word 'FAILED' along the side of 'Autodesk Design Review 2012'. I am at a loss, so if anyone can assist with detailed instructions and screenshots, if able, I'd really appreciate. I'm unable to start my course, without this install. 😞
Thanks, in advance.
1 REPLY 1
Tony_Michniewicz
The most likely scenario is that the Revit Architecture and Material Library installations are failing due to the failure of the Design Review installation.  My suggestion would be to run the installation again but this time, disable the check box associated with Design Review on the product selection page.  This should allow the Revit Architecture and Material Library installations to complete successfully.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Administrator Productivity
