Installation & Licensing
New Member
1 Kudo
Post 1 of 5
Revit Architecture 2012 Installation Fail
2169 Views, 4 Replies
07-04-2011 10:28 AM
Hello, I've been trying for the past two days to install Revit Architecture 2012 and every time I try, the installiaiton fails. This is the message I get in the installiation log:
2011/7/4:13:16:34     RJSpencer     RJSPENCER-PC     Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\RJSPEN~1\AppData\Local\Temp\vcredist_x86_2010.log
2011/7/4:13:16:36     RJSpencer     RJSPENCER-PC     Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
Now I'm getting fustrated because I already have Visual C++ 2010 installed on my computer and I'm getting more fustrated because the installer should see this and skip this step, correct?
I'm running an Alienware M11x, 4GB Ram, Windows 7 Home Premium 64-Bit.
EDIT: I just wanted to add that I've already sucessfully installed and ran AutoCAD Architecture 2012 and Sketchbook Pro 2011 on this system, so I know it can run autodesk software.
897 Kudos
Post 2 of 5
Re: Revit Architecture 2012 Installation Fail
07-05-2011 01:57 PM in reply to: rejspencer
Copy the contents to your hard drive and edit the setup.ini file to remove the prerequisite check for Visual C++.
See this link for an example of how to edit the setup.ini file:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12002434&linkID=9240617
New Member
0 Kudos
Post 3 of 5
08-18-2011 02:29 AM in reply to: TravisNave
that doesn't work for revit 2012 that only works for autocad
New Member
1 Kudo
Post 4 of 5
12-23-2011 11:43 AM in reply to: rejspencer
Just uninstall Microsoft Visual C++ 2010 Redistributable from your computer  and try again.. This worked for me!
New Member
0 Kudos
Post 5 of 5
06-30-2013 07:35 AM in reply to: rejspencer
Many thanks, uninstalling the C++ 2010 was the solution... Many many thx!!! :smileyhappy:
