I have just installed autodesk civil,3ds,inventor revit architecture and a few others and all except the revit arch finds the server network license, I have reinstalled it and currently downloading the installer again. we are using HP and Ace desktops with a 64 bit image.
we are with a school district district and so far 2 additional schools have run into this issue, but the other autodesk products that are using the same license server work correctly.
need more info
is there an error message?
DarrenP
are you using the Educational Master Suite 2014?
DarrenP
'm sure I assume so, its from a link that Autodesk sent us as a district but it doesn't say
you probably need to find that out
if it is there is another thread on this already
it could be a bug with the Educational Master Suite 2014
i would contact your educational license supplier and have them create a case with autodesk
DarrenP
