Installation & Licensing
Revit Archictecture 2014 can't find license server
5 REPLIES 5
nettechguy
995 Views, 5 Replies
I have just installed autodesk civil,3ds,inventor revit architecture and a few others and all except the revit arch finds the server network license, I have reinstalled it and currently downloading the installer again. we are using HP  and Ace desktops with a 64 bit image.
we are with a school district district and so far 2 additional schools have run into this issue, but the other autodesk products that are using the same license server work correctly.
5 REPLIES 5
DarrenP
in reply to: nettechguy
need more info
is there an error message?
DarrenP
nettechguy
in reply to: DarrenP
this is what we are getting see attached
DarrenP
are you using the Educational Master Suite 2014?
DarrenP
nettechguy
'm sure I assume so, its from a link that Autodesk sent us as a district but it doesn't say
DarrenP
you probably need to find that out
if it is there is another thread on this already
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/License-server-does-not-support-this-featu...
it could be a bug with the Educational Master Suite 2014
i would contact your educational license supplier and have them create a case with autodesk
DarrenP
Administrator Productivity
