case 07058042
When starting revit two days ago I got the "license error 5.2.2" message, with 7 days before license expires. upon attempting repair, the reply I got from autodesk was: " The maximum number of activations has been reached for this serial number. This is a student version and can only be activated on one machine, as disclosed in your student license FAQ (refer to link below)."
However, I have this serial number on only one computer, and did not try to activate on another computer- which I then informed Autodesk. The return answer: "Our records show that this license will expire on 8/1/2014. Please also take note that this serial number was activated on 3/6/2012 and the attempts to activate the software today is on another machine. As what was mentioned in the previous email, student licenses can only be activated on a single machine. Please follow the steps in the previous email to transfer the license." However--My computer's liscense info indicates the liscense will expire 2/27/2012.
So there seems to be two issues here? 1) how can the same serial & key have two different documented expirations? and 2) I have Revit architecture 2012 installed in windows7 on a bootcamp partiton which I access both through bootcamp direct and through Parallels on my Macbook Pro with Lion 10.7; is this a source of Autodesk thinking I am trying to activate on a second computer?
Note, these problems are new since I installed a new HD Jan 19 2012 after a crash and had to reinstall Revit, Autocad, 3DS Design. I continue to have ongoing liscense issues every week now with at least one of these apps.
HELP. I am very very frustrated for months now.
Solved by bielskj. Go to Solution.
Hello 87424,
I checked your case and it seems that your issue has been resolved today. If you still need help, please let us know by either posting here or by replying to your case.
Thank you for the followup. The Revit issue was indeed resolved.
But know I have a new/recurring problem with AutoCad Architecture 2012. I am copying here the message I sent to c/s in the event you can assist more than they will given all the prior :
