Revit 2015 UR5 has the foillowing note in hte installation instructions:
Note: If you are an Autodesk Subscription Customer and have installed Autodesk Revit 2015 R2, please install Autodesk Revit 2015 Update Release 5 for R2. Refer to the Autodesk Revit 2015 R2 subscription download page.
There is no 2015 R2 UR 5 download on the product enhancements list or anywhere ele I can find...
Anyone knows where to find it? CADForum has a file listed, but when you look at the file info, it is actually a 'standard' UR5.
http://www.cadforum.cz/cadforum_en/download.asp?fileID=2284
Thank you!
Solved by Chris.Aquino. Go to Solution.
Edit: Found it. It seems your Autodesk Application manager knows if you have R2 or UR4 and downloads the appropriate version. Wish the note installation instructions in hte Knowledge base would mention that :-).
The R2 version of 2015 UR5 will be added to the R2 page in the Subscription Center at some point in the near future. The page has been updated, but the update has not yet pushed out. We are just waiting for the update at this point.
