Have been trying to install the 2015 REVIT student version and I am getting an install error. Here is the install log output for my latest attempt, any help?
2014/9/1:11:59:34 Chase CHASECLARK === Setup started on CHASECLARK by Chase ===
2014/9/1:11:59:34 Chase CHASECLARK Path_Length: 155
2014/9/1:11:59:34 Chase CHASECLARK Current Directory C:\Users\Chase\AppData\Local\Temp\_AICFFA.tmp
2014/9/1:11:59:34 Chase CHASECLARK Launch
2014/9/1:11:59:35 Chase CHASECLARK Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/SETUP_x64.ta...
2014/9/1:11:59:35 Chase CHASECLARK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Chase\AppData\Local\Temp\_AICFFA.tmp\Setup\RevitSetup.dll
2014/9/1:11:59:35 Chase CHASECLARK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/1:11:59:36 Chase CHASECLARK PageOpen LaunchDialog
2014/9/1:11:59:41 Chase CHASECLARK PageOpen LicenseDialog
2014/9/1:11:59:41 Chase CHASECLARK PageOpen ProductInfoDialog
2014/9/1:11:59:41 Chase CHASECLARK PageOpen ProductSelectionDialog2
2014/9/1:12:00:04 Chase CHASECLARK PageOpen FullProgressDialog
2014/9/1:12:00:04 Chase CHASECLARK Download Skipped VCREDIST2012X86 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012...
2014/9/1:12:00:04 Chase CHASECLARK Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/1:12:00:06 Chase CHASECLARK Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/1:12:00:06 Chase CHASECLARK Download Skipped VCREDIST2012X64 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/VCREDIST2012...
2014/9/1:12:00:06 Chase CHASECLARK Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2015\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/1:12:00:07 Chase CHASECLARK Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/1:12:00:07 Chase CHASECLARK Download Skipped RVT2015 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64....
2014/9/1:12:00:07 Chase CHASECLARK Installing Autodesk® Revit® 2015: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2015\x64\en-us\RVT2015\RVT2015.mst;C:\Users\Chase\AppData\Local\Temp\_AICFFA.tmp\x64\RVT2015\RVT2015-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/1:12:02:07 Chase CHASECLARK Install Autodesk® Revit® 2015 Succeeded
2014/9/1:12:02:08 Chase CHASECLARK Download Skipped RVT2015_en-us http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/RVT2015_x64_...
2014/9/1:12:02:08 Chase CHASECLARK Installing Autodesk® Revit® 2015 Language Pack: TRANSFORMS="C:\Users\Chase\AppData\Local\Temp\_AICFFA.tmp\_la2CCA.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/1:12:02:22 Chase CHASECLARK Install Autodesk® Revit® 2015 Language Pack Succeeded
2014/9/1:12:02:22 Chase CHASECLARK Installing Autodesk Workflows 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/1:12:02:26 Chase CHASECLARK Install Autodesk Workflows 2015 Succeeded
2014/9/1:12:02:27 Chase CHASECLARK Download Play CMILL2015 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015.ta...
2014/9/1:12:05:52 Chase CHASECLARK Download Aborted CMILL2015 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILL2015.ta...
2014/9/1:12:05:52 Chase CHASECLARK Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603
2014/9/1:12:05:55 Chase CHASECLARK Rollback Autodesk Workflows 2015 Succeeded
2014/9/1:12:06:05 Chase CHASECLARK Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2014/9/1:12:08:41 Chase CHASECLARK Rollback Autodesk® Revit® 2015 Succeeded
2014/9/1:12:08:41 Chase CHASECLARK Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/1:12:08:42 Chase CHASECLARK Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Hello and welcome to the forum,
The install appears to have failed installing the low image library
"Install Autodesk Material Library 2015 - Low Image Library Failed Download Failed, Installation aborted, Result=1603"
Can you try the solutions linked below?
If it truely was a download failure you might also want to try the full installer which pre downloads rather than downloading as you go. You can find direct download links to the full installers on the virtual agent.
Select the 2nd Choice "Download Links "
Select your product
You are now presented with the choice to download your software.
Hey please go through the given link to install revit 2015
http://www.trainingchennai.com/how-to-install-revit-architecture.html
hope this help you.
Thankyou
@Anonymous
This posting is 2 years old and hopefully by now the OP has the application installed and is using it..
Mark Lancaster
& Autodesk Services MarketPlace Provider
