I'm having trouble with installing Revit Architecture on my brand new laptop.
I've recently bought a new Asus F550L and have attempted to download/install Revit on it 4 x times now. All the system requirements match up with the requirements needed to download Revit 2015, and I've also downloaded the prerequisites needed. The download seems to be going fine for about an hour, then I get a message that comes up saying "Installation Complete. Some products failed to install." (See attached image)
It has been racking my brain as I can't understand why it's failing! I've downloaded previous versions of Revit on other laptops without any dramas.
Has anyone else had this problem before? Can anyone help me please? I'm quite desperate as it is essential that I be able to use Revit!
Thank you in advance for your help!
it says for more information to read the install log
what does the log say? that will tell you where it is failing
DarrenP
Thanks for replying Darren.
When I opened up the install log, this is what came up.....
I have the same problem on my ASUS laptop
this is the log file says:
2017/4/24:00:30:56 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:00:30:56 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:00:30:56 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm
2017/4/24:00:30:56 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:00:30:56 Ahmad Shtayya DESKTOP-8UEF3I1 CommandLine
2017/4/24:00:30:56 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI741C.tmp
2017/4/24:00:31:17 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:00:30:59 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:00:30:59 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:00:30:59 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI741C.tmp
2017/4/24:00:30:59 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:00:31:00 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI741C.tmp\Setup\RevitSetup.dll
2017/4/24:00:31:00 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:00:31:09 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI741C.tmp\Setup\RevitSetup.dll
2017/4/24:00:31:09 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/4/24:00:31:17 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LaunchDialog
2017/4/24:00:31:52 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LicenseDialog
2017/4/24:00:31:56 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductInfoDialog
2017/4/24:00:31:56 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductSelectionDialog2
2017/4/24:00:32:02 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen FullProgressDialog
2017/4/24:00:32:02 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/4/24:00:32:08 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/4/24:00:32:08 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/4/24:00:32:15 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/4/24:00:32:15 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:00:32:21 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/4/24:00:32:21 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2017/4/24:00:32:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2017/4/24:00:32:28 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2017/4/24:00:32:34 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/4/24:00:32:34 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2017/4/24:00:32:39 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/4/24:00:32:39 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/24:00:32:40 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/24:00:32:40 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/24:00:32:41 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/24:00:32:41 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:43 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:00:32:43 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:46 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:00:32:46 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:48 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:00:32:48 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:50 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:00:32:50 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:52 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:00:32:52 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:56 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:00:32:56 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:32:59 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:00:32:59 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/4/24:00:33:07 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2017/4/24:00:33:07 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:00:33:15 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/4/24:00:33:15 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2017/4/24:00:33:16 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:00:33:18 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:00:33:19 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:00:33:21 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:00:33:22 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:00:33:24 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:00:33:26 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:00:33:26 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:00:33:26 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/4/24:00:33:26 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/4/24:00:33:26 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/4/24:00:33:29 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen InstallCompleteDialog
2017/4/24:00:34:21 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:00:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:00:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:00:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm
2017/4/24:00:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:00:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 CommandLine
2017/4/24:00:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI247C.tmp
2017/4/24:00:40:52 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:00:40:44 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:00:40:44 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:00:40:44 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI247C.tmp
2017/4/24:00:40:44 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:00:40:44 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI247C.tmp\Setup\RevitSetup.dll
2017/4/24:00:40:44 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:00:40:51 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI247C.tmp\Setup\RevitSetup.dll
2017/4/24:00:40:51 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/4/24:00:40:52 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LaunchDialog
2017/4/24:00:41:50 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LicenseDialog
2017/4/24:00:42:07 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductInfoDialog
2017/4/24:00:42:07 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductSelectionDialog2
2017/4/24:00:42:23 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen FullProgressDialog
2017/4/24:00:42:23 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2017/4/24:00:42:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2017/4/24:00:42:28 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/24:00:42:30 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/24:00:42:30 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/24:00:42:32 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/24:00:42:33 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:34 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:00:42:35 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:38 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:00:42:39 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:41 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:00:42:42 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:44 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:00:42:44 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:45 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:00:42:46 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:50 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:00:42:50 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:00:42:52 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:00:42:52 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:00:42:59 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/4/24:00:43:00 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:00:43:02 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:00:43:03 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:00:43:05 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:00:43:06 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:00:43:08 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:00:43:09 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:00:43:09 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:00:43:09 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/4/24:00:43:09 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2017/4/24:00:43:11 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen InstallCompleteDialog
2017/4/24:00:52:19 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:11:00:22 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:11:00:22 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:11:00:22 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm
2017/4/24:11:00:22 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:11:00:22 Ahmad Shtayya DESKTOP-8UEF3I1 CommandLine
2017/4/24:11:00:22 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI7D73.tmp
2017/4/24:11:00:29 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:11:00:27 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:11:00:27 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:11:00:27 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI7D73.tmp
2017/4/24:11:00:27 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:11:00:27 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI7D73.tmp\Setup\RevitSetup.dll
2017/4/24:11:00:27 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:11:00:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI7D73.tmp\Setup\RevitSetup.dll
2017/4/24:11:00:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/4/24:11:00:29 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LaunchDialog
2017/4/24:11:03:23 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LicenseDialog
2017/4/24:11:03:30 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductInfoDialog
2017/4/24:11:03:30 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductSelectionDialog2
2017/4/24:11:03:34 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen FullProgressDialog
2017/4/24:11:03:35 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2017/4/24:11:03:42 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2017/4/24:11:03:42 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2017/4/24:11:03:50 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2017/4/24:11:03:50 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:11:03:58 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2017/4/24:11:03:58 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2017/4/24:11:04:02 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2017/4/24:11:04:02 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161: "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2008SP1.6161\vcredist_x86.exe" /q
2017/4/24:11:04:10 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161 Succeeded
2017/4/24:11:04:10 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2017/4/24:11:04:15 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2017/4/24:11:04:15 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2017/4/24:11:04:21 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2017/4/24:11:04:21 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2012 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2017/4/24:11:04:22 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2017/4/24:11:04:23 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2012 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2017/4/24:11:04:25 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2017/4/24:11:04:25 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/24:11:04:26 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/24:11:04:26 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/24:11:04:27 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/24:11:04:27 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:11:04:28 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:30 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:11:04:30 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:32 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:11:04:32 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:34 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:11:04:34 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:35 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:11:04:35 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:37 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:11:04:37 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:11:04:39 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:11:04:39 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:11:04:45 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/4/24:11:04:47 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:11:04:49 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:11:04:51 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:11:04:53 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:11:04:55 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:11:04:57 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2017/4/24:11:04:59 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2017/4/24:11:05:01 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen InstallCompleteDialog
2017/4/24:11:36:30 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:20:38:53 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:20:38:53 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:20:38:53 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm
2017/4/24:20:38:53 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:20:38:53 Ahmad Shtayya DESKTOP-8UEF3I1 CommandLine
2017/4/24:20:38:53 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI95F1.tmp
2017/4/24:20:39:37 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:20:38:57 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:20:38:57 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:20:38:57 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AI95F1.tmp
2017/4/24:20:38:57 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:20:38:58 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI95F1.tmp\Setup\RevitSetup.dll
2017/4/24:20:38:58 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:20:39:21 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AI95F1.tmp\Setup\RevitSetup.dll
2017/4/24:20:39:21 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/4/24:20:39:37 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LaunchDialog
2017/4/24:20:40:37 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LicenseDialog
2017/4/24:20:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductInfoDialog
2017/4/24:20:40:40 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductSelectionDialog2
2017/4/24:20:40:46 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen FullProgressDialog
2017/4/24:20:40:47 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x86): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/24:20:40:47 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/24:20:40:47 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/24:20:40:51 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/24:20:40:51 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:40:54 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:20:40:54 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:40:58 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:20:40:59 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:41:02 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:20:41:02 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:41:04 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:20:41:04 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:41:05 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:20:41:06 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:41:10 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:20:41:11 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:20:41:13 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:20:41:13 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "D:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:20:41:20 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/4/24:20:41:21 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:20:41:23 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:20:41:24 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:20:41:26 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:20:41:28 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:20:41:30 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:20:41:31 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:20:41:31 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:20:41:31 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/4/24:20:41:39 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen InstallCompleteDialog
2017/4/24:20:41:42 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:21:50:06 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:21:50:06 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:21:50:06 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm
2017/4/24:21:50:06 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:21:50:06 Ahmad Shtayya DESKTOP-8UEF3I1 CommandLine
2017/4/24:21:50:06 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AIC998.tmp
2017/4/24:21:50:11 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:21:50:07 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:21:50:07 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:21:50:07 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AIC998.tmp
2017/4/24:21:50:07 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:21:50:07 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AIC998.tmp\Setup\RevitSetup.dll
2017/4/24:21:50:07 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:21:50:09 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AIC998.tmp\Setup\RevitSetup.dll
2017/4/24:21:50:09 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/4/24:21:50:11 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LaunchDialog
2017/4/24:21:51:09 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LicenseDialog
2017/4/24:21:51:18 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductInfoDialog
2017/4/24:21:51:18 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductSelectionDialog2
2017/4/24:21:51:43 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen FullProgressDialog
2017/4/24:21:51:43 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/24:21:52:00 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/24:21:52:00 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/24:21:52:16 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/24:21:52:16 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:20 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:21:52:20 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:23 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:21:52:23 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:26 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:21:52:26 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:21:52:28 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:30 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:21:52:30 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:33 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:21:52:33 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:21:52:35 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:21:52:35 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:21:52:43 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/4/24:21:52:44 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:21:52:46 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:21:52:47 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:21:52:48 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:21:52:50 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:21:52:51 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:21:52:52 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:21:52:52 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:21:52:52 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
2017/4/24:21:52:52 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen InstallCompleteDialog
2017/4/24:22:00:57 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:22:03:46 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:22:03:46 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:22:03:46 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm
2017/4/24:22:03:46 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:22:03:46 Ahmad Shtayya DESKTOP-8UEF3I1 CommandLine
2017/4/24:22:03:46 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AIB06F.tmp
2017/4/24:22:03:49 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup ended ===
2017/4/24:22:03:47 Ahmad Shtayya DESKTOP-8UEF3I1 === Setup started on DESKTOP-8UEF3I1 by Ahmad Shtayya ===
2017/4/24:22:03:47 Ahmad Shtayya DESKTOP-8UEF3I1 Path_Length: 155
2017/4/24:22:03:47 Ahmad Shtayya DESKTOP-8UEF3I1 Current Directory C:\Users\AHMADS~1\AppData\Local\Temp\_AIB06F.tmp
2017/4/24:22:03:47 Ahmad Shtayya DESKTOP-8UEF3I1 Launch
2017/4/24:22:03:47 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AIB06F.tmp\Setup\RevitSetup.dll
2017/4/24:22:03:47 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2017/4/24:22:03:48 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\AHMADS~1\AppData\Local\Temp\_AIB06F.tmp\Setup\RevitSetup.dll
2017/4/24:22:03:48 Ahmad Shtayya DESKTOP-8UEF3I1 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2017. URLTitle= URLLink=
2017/4/24:22:03:49 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LaunchDialog
2017/4/24:22:04:42 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen LicenseDialog
2017/4/24:22:04:54 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductInfoDialog
2017/4/24:22:04:54 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen ProductSelectionDialog2
2017/4/24:22:05:16 Ahmad Shtayya DESKTOP-8UEF3I1 PageOpen FullProgressDialog
2017/4/24:22:05:16 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x86_2015.log
2017/4/24:22:05:18 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2017/4/24:22:05:18 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2015.log
2017/4/24:22:05:18 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2017/4/24:22:05:18 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:21 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:22:05:21 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:23 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:22:05:23 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:26 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:22:05:26 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:28 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:22:05:28 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:29 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:22:05:29 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:32 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:22:05:32 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2017" SETUP_PACKAGECODE={7346B4A0-1700-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" PACKAGEUPI={BB7722F7-1BA6-4B90-90DA-0C00CA6AD0FC} ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2017/4/24:22:05:34 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:22:05:34 Ahmad Shtayya DESKTOP-8UEF3I1 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_2017_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMADS~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2017/4/24:22:05:40 Ahmad Shtayya DESKTOP-8UEF3I1 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2017/4/24:22:05:42 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2017/4/24:22:05:44 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2017/4/24:22:05:44 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2017/4/24:22:05:46 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2017/4/24:22:05:47 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2017/4/24:22:05:49 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2017/4/24:22:05:50 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2017/4/24:22:05:50 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2017/4/24:22:05:50 Ahmad Shtayya DESKTOP-8UEF3I1 Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
@Anonymous
May I ask why you started another posting here about the same thing when you are already posted here? Please refrain from doing this because its just leads to duplicate steps and conflicting information.
Update: Also may I ask why as CEO of a commercial company are you trying to install an educational (free) version of the application?
Mark Lancaster
& Autodesk Services MarketPlace Provider
