Installation & Licensing
Revit 2015 Installation isn't working
1 REPLY 1
clang1066
215 Views, 1 Reply
Before starting I changed my computer settings to "never" sleep.  When downloading the Revit 2015 software, I inadvertantly used the default install from Autodesk instead of the Browser Download.  It appeared to be "exploding" the zipped files, but then the routine "hung" for about an hour, so I cancelled it and deleted the downloaded file from my Downloads folder.  Did not "uninstall" because the Revit software install never started.  Then went back into Autodesk, re-downloaded the Revit program . . . this time it got all the way through to launching the install in Revit - when I entered my serial number and product key, the installation just stopped - the "next" button was not active.
I checked for possible problems, turned off my firewall.  I can't seem to get the Revit 2015 Install to start again.   I checked installed programs and Revit 2015 is not listed, so I can't uninstall it and start over.  Do I still need to be logged into AutoDesk while the the install runs?
I've attached the directory tree in my Autodesk folder.  Do I need to erase all the files and start the entire process over again?
Suggestions?
1 REPLY 1
dembkod
in reply to: clang1066
clang1066,
Hello. If you enter the serial and product key, your next button should be active unless you entered a bad key or serial. If the installer is corrupt, I would download from here:
http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
Delete the files in the c:\autodesk\ folder and then redownload.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
