Installation & Licensing
Revit 2015 installation fails, Result 1619
14 REPLIES 14
Message 1 of 15
3894 Views, 14 Replies
Installation Continuously fails with this being the last thing on the log file. How can i get the instaall to work?
2014/9/24:12:46:45 Russell RUSSELLJARVIS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/24:12:46:45 Russell RUSSELLJARVIS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
14 REPLIES 14
Message 2 of 15
dembkod
Russell.Jarvis
Hello. Uninstall the C++ entries on your machine and then try to install. Clearly, you are being blocked by the existing version. I would uninstall ALL of them while I was in there.
Thank you for taking part in our community!
David Dembkoski
Message 3 of 15
in reply to: dembkod
How do i uninstall the C++ enteries.....?
Message 4 of 15
How do i uninstall the C++ enteries...?
Do i have to uninstall AutoCad to get Revit to install? im not sure what you mean
Message 5 of 15
dembkod
Russell.Jarvis
They are in the Control Panel in your program list. You uninstall like any regular program. Just the C++ entries, Revit has nothing to do with this. It is a separate program. If it is installed, ignore it.
David Dembkoski
Message 6 of 15
TravisNave
The 1619 are not indicitive of your error.  Your actual error is higher in the log file.
Install	Autodesk Material Library 2015 - Medium Image Library	Failed	Download Failed, Installation aborted, Result=1603
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 7 of 15
in reply to: TravisNave
That still doesn't work. Is there someone I can actually talk to over the phone or who can take over my computer to get Revit installed, it really is quite urgent
Russell A Jarvis
Jarvis Developments
PO Box 9182
Billericay Essex
CM11 1WW
Tel: 01277 659211
Mobile: 07962346661
[http://betterment.co.uk/wp-content/uploads/2012/07/NHBC_Logo.jpg]
Message 8 of 15
I still am not able to successfully install Revit. Is there someone i can speak to over the phone to get this resolved....? It is urgent
Message 9 of 15
TravisNave
If you have download the full product from the virtual assistant and installation is still failing, then you should post a new installation log.  You should no longer have the failed download line.  There should be a new issue now that can probably be resolved.
Phone support is typically handled through your Value-Added Reseller.  This is a peer support forum.
Autodesk Forums:
Message 10 of 15
ukdxb012
Are you still facing the same issue regarding Material libraries? If so, you can get them from here... http://knowledge.autodesk.com/support/autocad-map-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Please install them and try again with the install. If it still won't work, as stated previously, upload another log for users of the forums to investigate and help out.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 11 of 15
in reply to: ukdxb012
I am having the same issue above. However, it say that the installer must be ran first (error)
Message 12 of 15
ukdxb012
Hi @Anonymous
Please could you upload your log file from the %temp% directory. This will help us to determine the issue.
Also, if you have any screenshots, these would be useful.
Duncan Brannan
Twitter | LinkedIn
Message 13 of 15
markus61616
I have the same problem -did anyone solved the problem?
Thanks a lot,
Markus
Message 14 of 15
abhijitmenonu
I uninstalled all the c++ files and installed revit 2014 again.But the installation failed .Kindly lindentify the problem and waiting for the quick solution. I have attached my log file.
Message 15 of 15
abhijitmenonu
Administrator Productivity
