Installation Continuously fails with this being the last thing on the log file. How can i get the instaall to work?
2014/9/24:12:46:45 Russell RUSSELLJARVIS Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/24:12:46:45 Russell RUSSELLJARVIS Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
Hello. Uninstall the C++ entries on your machine and then try to install. Clearly, you are being blocked by the existing version. I would uninstall ALL of them while I was in there.
Thank you for taking part in our community!
How do i uninstall the C++ enteries...?
Do i have to uninstall AutoCad to get Revit to install? im not sure what you mean
They are in the Control Panel in your program list. You uninstall like any regular program. Just the C++ entries, Revit has nothing to do with this. It is a separate program. If it is installed, ignore it.
The 1619 are not indicitive of your error. Your actual error is higher in the log file.
Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
I still am not able to successfully install Revit. Is there someone i can speak to over the phone to get this resolved....? It is urgent
If you have download the full product from the virtual assistant and installation is still failing, then you should post a new installation log. You should no longer have the failed download line. There should be a new issue now that can probably be resolved.
Phone support is typically handled through your Value-Added Reseller. This is a peer support forum.
I have the same problem -did anyone solved the problem?
Thanks a lot,
Markus
I uninstalled all the c++ files and installed revit 2014 again.But the installation failed .Kindly lindentify the problem and waiting for the quick solution. I have attached my log file.
