Hello i have been trying to install Revit 2015 multible times now and alwas get this massage:
i have tried to unstall my current version of microsoft visual, but it did not help, i have also tried to turn of my firewall and run the install file as admin, but that dident help either.
i am out of ideas, and nobody at my school is able to tell me whats wrong, hope for a fast reply, becouse i am surpose to start working in revit this weekend.
Solved by TravisNave. Go to Solution.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
I have the same problem, but I cant even open the virtual agent, please help!!!!!!!!!
i have the same problem and this solution is not working for me!
any other ideas??
Gilad
I have been trying to install Revit 2015 for 3 days,and the installation keeps stopping at some point.
I installed the Tools and Utilites,and the Revit Content library,but it freezes when comes to install the application itself.
I turned off my Firewall and disabled the Antivuris program and it makes no difference.
I have to say,my network connection is a bit weak,but it doesn't prevent for downloading other applications and files.
I'd like to know if that's the problem and if so,I will look for different place to install.
Hi @Anonymous and welcome to the Autodesk Community!
Can you please keep your anti-virus and firewall fully disable, delete all installation files you've downloaded so far and download the program from our Virtual Agent linked here?
Thank you,
I have the same issue. I have tried using google chrome, firewall off, etc etc and nothing. I trully need to have the program installed.
Is there a list of MUST thing to make sure that the installation just go well at once?
Gabriel.
Thanks I followed your directions and it worked! Thanks.
My Advise: make a BIG NOTE in the download page link with that information.
Thanks again,
Gab.
Still having the same problem after:
1- Downloading through the Vistual Assistant
2- Uninstalling 11 Microsoft Visual C++ programs that reappear every time I try to install Revit 2016
Any further guidance ?
Hi, I had extract problem for Revit 2016. After trying to the link for virtual agent, I saw the installation was 2 parts. I'm downloading the 2nd part now and I think will work after that. Thanks very much.
