So this story starts with me baldly installed Autodesk Revit 2015 on my old, slow, i3 school pc with no problem, except that it doesn't run smooth at all.
Then I thought... What is the point with a gorgious drawing program, that I can't use at all, because of the lack of computingpower.
I soon bought a lenovo y50 with windows 8.1.
So extremely thrilled I sat and waited with the idea of countless hours with revit inprinted in my mind as the loading bar crawled towards something that would be a big dissapointment.
When the installer was done, it had failed on 3 packs and on all there was a red 'x'.
2014/10/7:18:25:55 Torbjørn LENOVO-PC Installing Autodesk Material Library 2015 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/7:18:26:08 Torbjørn LENOVO-PC Install Autodesk Material Library 2015 - Low Image Library Succeeded
2014/10/7:18:26:08 Torbjørn LENOVO-PC Installing Autodesk® BIM 360™ Add-in for Revit® 2015: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2015" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2015Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/10/7:18:26:10 Torbjørn LENOVO-PC Install Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded
2014/10/7:18:26:10 Torbjørn LENOVO-PC Download Play CMILM2015 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015.ta...
2014/10/7:18:29:13 Torbjørn LENOVO-PC Download Aborted CMILM2015 http://trial2.autodesk.com/SWDLDNET4/2015/RVT/WI/{4E6C5405-BECC-494E-A4AA-38E207D87A03}/CMILM2015.ta...
2014/10/7:18:29:13 Torbjørn LENOVO-PC Install Autodesk Material Library 2015 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2014/10/7:18:29:14 Torbjørn LENOVO-PC Rollback Autodesk® BIM 360™ Add-in for Revit® 2015 Succeeded
2014/10/7:18:29:28 Torbjørn LENOVO-PC Rollback Autodesk Material Library 2015 - Low Image Library Succeeded
2014/10/7:18:29:42 Torbjørn LENOVO-PC Rollback Autodesk Material Library 2015 - Base Image Library Succeeded
2014/10/7:18:30:07 Torbjørn LENOVO-PC Rollback Autodesk Material Library 2015 Succeeded
2014/10/7:18:30:09 Torbjørn LENOVO-PC Rollback Autodesk Workflows 2015 Succeeded
2014/10/7:18:30:15 Torbjørn LENOVO-PC Rollback Autodesk® Revit® 2015 Language Pack Succeeded
2014/10/7:18:32:20 Torbjørn LENOVO-PC Rollback Autodesk® Revit® 2015 Succeeded
2014/10/7:18:32:51 Torbjørn LENOVO-PC Rollback Autodesk® Revit® Content Libraries 2015 Succeeded
2014/10/7:18:32:51 Torbjørn LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/10/7:18:32:51 Torbjørn LENOVO-PC Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/10/7:18:32:52 Torbjørn LENOVO-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
It was hard to contact autodesk, so I took it here.
So I want to know how to install revit and is there any way to redirect my licence from my trashy pc to the new one, as I won't be using 2 licences.
THANKS for the help in advance.
Torbjørn from Norway.
You errors are with the download failing
Try downloading using the Virtual Agent then install again.
Danny
