i can´t install Revit 2015 in my Laptop with Windows 8.1 Pro.
this is the log of last installation
2014/9/30:18:06:25 Sebastián SEBASTIANUN === Setup started on SEBASTIANUN by Sebastián ===
2014/9/30:18:06:25 Sebastián SEBASTIANUN Path_Length: 155
2014/9/30:18:06:25 Sebastián SEBASTIANUN Current Directory C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm
2014/9/30:18:06:25 Sebastián SEBASTIANUN Launch
2014/9/30:18:06:25 Sebastián SEBASTIANUN CommandLine
2014/9/30:18:06:25 Sebastián SEBASTIANUN Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI7B7B.tmp
2014/9/30:18:06:30 Sebastián SEBASTIANUN === Setup ended ===
2014/9/30:18:06:26 Sebastián SEBASTIANUN === Setup started on SEBASTIANUN by Sebastián ===
2014/9/30:18:06:26 Sebastián SEBASTIANUN Path_Length: 155
2014/9/30:18:06:26 Sebastián SEBASTIANUN Current Directory C:\Users\SEBAST~1\AppData\Local\Temp\_AI7B7B.tmp
2014/9/30:18:06:26 Sebastián SEBASTIANUN Launch
2014/9/30:18:06:26 Sebastián SEBASTIANUN Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\SEBAST~1\AppData\Local\Temp\_AI7B7B.tmp\Setup\RevitSetup.dll
2014/9/30:18:06:26 Sebastián SEBASTIANUN Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/9/30:18:06:30 Sebastián SEBASTIANUN Install CustomCallback Info Invoking custom callback for details: [RCL2015] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\SEBAST~1\AppData\Local\Temp\_AI7B7B.tmp\Setup\RevitSetup.dll
2014/9/30:18:06:30 Sebastián SEBASTIANUN Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Si se anula la selección de la instalación del contenido, habrá opciones de configuración esenciales en Autodesk® Revit® 2015 que quedarán afectadas. URLTitle= URLLink=
2014/9/30:18:06:30 Sebastián SEBASTIANUN PageOpen LaunchDialog
2014/9/30:18:06:55 Sebastián SEBASTIANUN PageOpen LicenseDialog
2014/9/30:18:06:59 Sebastián SEBASTIANUN PageOpen ProductInfoDialog
2014/9/30:18:07:26 Sebastián SEBASTIANUN PageOpen ProductSelectionDialog2
2014/9/30:18:07:31 Sebastián SEBASTIANUN PageOpen FullProgressDialog
2014/9/30:18:07:31 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\SEBAST~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/9/30:18:07:37 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/9/30:18:07:38 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/9/30:18:07:39 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
2014/9/30:18:07:39 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/9/30:18:07:40 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
2014/9/30:18:07:40 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=es-es SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/30:18:07:43 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/9/30:18:07:43 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=es-es SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/30:18:07:52 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/9/30:18:07:52 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=es-es SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/30:18:07:59 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/9/30:18:07:59 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=es-es SETUP_PACKAGENAME="Autodesk Revit 2015" SETUP_PACKAGECODE={7346B4A0-1500-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/9/30:18:08:05 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/9/30:18:08:05 Sebastián SEBASTIANUN Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\Autodesk_Revit_2015_Spanish_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\SEBAST~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/9/30:18:08:18 Sebastián SEBASTIANUN Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/9/30:18:08:21 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/9/30:18:08:24 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/9/30:18:08:27 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/9/30:18:08:29 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/9/30:18:08:30 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Installation aborted, Result=1619
2014/9/30:18:08:30 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/30:18:08:30 Sebastián SEBASTIANUN Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/9/30:18:08:30 Sebastián SEBASTIANUN PageOpen InstallCompleteDialog
2014/9/30:21:10:38 Sebastián SEBASTIANUN === Setup ended ===
Solved by TravisNave. Go to Solution.
I would start here:
If you still have problems and the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
