I have a deployment stored on a DFS share for Revit 2015 that I created from BDS Premium and it installs silently without issue when I launch it as an admin user. However, our IT department wants to use SCCM to deploy the application and they are running into an issue.
They are installing the app under the system account (e.g. whoami returns nt authority\system). When they do this, as soon as the deployment hits the content libraries, they are prompted for network credentials. The odd part is that if they cancel the dialog box, the install proceeds normally. This is not an issue with SCCM because I can replicate the issue manually when using the system account to launch the deployment.
To replicate the issue you need PSExec:
Does anyone have an idea what is going on? We obviously cannot push a deployment when there is a mysterious dialog popping up for attention.
Solved by r.robert.bell. Go to Solution.
Hi Robert,
What customization has been done to your deployment? Could it be prehaps your deployment is customized to have Revit content on a Share on your domain and the system account is getting stuck because it has no domain access when it tried to check that directory?
Yes, the deployment has been modified to use shared locations for the content. Please see the attached image.
If the content has already been installed to the shared location, is there any reason to include the Content Libraries in the deployment when I'm providing a custom Revit.ini file for the actual Revit deployment?
If the deployment has custom content paths on the network the installer is going to try and check that patch during install if it's specified. If you are deploying with SCCM you may want to just leave those paths and the defaut and then make the changes after the fact with a custom profile or something like that.
I was able to resolve the issue by selecting to not install the content. The content already exists on the network and I deploy using a custom Revit.ini with the correct content paths already defined so I need no need to have the deployment install the content just to specify the shared paths.
