After installing revit 2015, I found that the content libraries are missing. I have uninstall the Revit Content Library, and have installed Revit again several times but am not seeing Revit Content Library getting installed. Please help.
Thank you,
Binu
Solved by DarrenP. Go to Solution.
DarrenP
Revit 2015 libraries and template files are not installed. I tried several times to install and uninstall the Revit content libraries 2015 following the Autodesk support, all folders are where it supposed to be installed (C:\ProgramData\Autodesk\RVT 2015) but it does not contain any file.
There have been numerous posts about Revit content installation failures and a new post has been created to focus our troubleshooting efforts. If you continue to encounter this problem, please refer to this post for the latest details on this issue.
Tony Michniewicz
Autodesk Revit QA
