Installation & Licensing
Revit 2014 Windows Install failed
1 REPLY 1
432 Views, 1 Reply
Hello! I'm having some issues with installing Revit 2014 On Windows 8 and I'd like some help :S
I've recieved the message "An error occured while installing this product. For more information view the installation log file", after it has "finished" the installation. I'm not really that good with computers, so I've uploaded the installation log file to this post and hopefully it'll help in solving this problem.
Thank You!
1 REPLY 1
TravisNave
You are experiencing a current issue with the download of the software components.
Install	Autodesk® Revit® 2014 Language Pack	Failed	Download Failed, Installation aborted, Result=1603
 I have a KB work-around on this in my signature.  But basically, you need to download from the virtual assistant here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
