Installation & Licensing
Revit 2014 Student Version Installaton Error
1 REPLY 1
s.g321
298 Views, 1 Reply
Please help. I've researched multiple forums and options on how to fix this installation issue.  I have a Windows 8 operating system, 64-bit and already have the AutoCAD 2014 student version successfully installed. Whenever I try to install Revit 2014 however, I get an error.
Attached in NotePad are the two error logs I get.
1 REPLY 1
TravisNave
in reply to: s.g321
It is an aborted download.
Install	Autodesk Material Library 2014 - Medium Image Library	Failed	Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
