Please help. I've researched multiple forums and options on how to fix this installation issue. I have a Windows 8 operating system, 64-bit and already have the AutoCAD 2014 student version successfully installed. Whenever I try to install Revit 2014 however, I get an error.
Attached in NotePad are the two error logs I get.
It is an aborted download.
Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Good Luck!
