My research to this point has included the links I show below, but I just can't seem to get past the 1603 and 1619 errors when trying to install Revit 2014 Student. I am mystified as to how I could keep getting the "prerequisite" error related to the Visual C++ programs, as this is on a brand new Win 8.1 16gb Dell PC with only Dell's preloaded software on it to date.
I am trying to do this for my wife, for whom through her local coommunity college course we've activated the 3 year student license for Revit 2014, obtaining a serial number and product key.
Before my last 3 attempts, I have uninstalled various combinations of some or all of the visual C++ programs. I've attached a pic showing all of those currently on the PC as of after the 4th failed install attempt.
http://delphintipz.blogspot.com/2011/09/microsoft-visual-c-2005-redistributable.html
Also noting I have awareness of this Microsoft site, but not sure how I would act on it:
http://www.microsoft.com/en-us/download/details.aspx?id=5555
So the two attachments here are the log for my 4th failed install, and the pic mentioned above.
Solved by TravisNave. Go to Solution.
This is the error you are actually getting:
Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
