When starting Revit 2014 for the first time after a restart, I get the message "license error 10: cannot start adlm". Revit does continue to launch.
This started after installing Service Pack 1. Tried Repair, but did not resolve problem. Also uninstalled and reinstalled, but that did not help.
Revit 2013 is unaffected.
Single user stand-alone license.
Windows 7, 64-bit
Solved by avto. Go to Solution.
Hi Doug,
Could you please check TS22241522 and let us know if it helps in this case.
Thank you for taking part in our community!
That seems to have resolved the issue.
Thank you!
Hey I am having the same problem but I cannot click on that link you posted to fix it. Could you explain to me how to fix this? I am getting Error 10: cannot start adlm whenever I open my recently installed Revit 2014.
Hi Louis,
Error 10 typically means that you've exceeded your activation limit and now must contact our Activation and Registration team for a manual activation. Please see this solution on how to do so. If you have any other questions please respond to this post. Thank you!
It seems that I exceeded my activation limit but what else can I do? I realy need the program.
Thank you very much!
Hi Jessica
I have the same problem! license error 10: cannot start adlm. What can I do??? I really need the program.
Thanks!
Hi @Anonymous,
Did you try the solutions and troubleshooting listed above? What was the result or how far were you able to make in those steps? Any further details would be appreciated. Thank you!
