To anyone who may be able to offer some assistance;
I initially had an issue with the installation of the materials library. To rectify this issue I therefore decided to follow the advice of the autodesk support team on preparing my system before reinstallation.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
I am confident I completed all the steps indicated. However the installation failed as a result of both;
2013/10/16:11:48:30MahonriMAHONRI-PCInstallAutodesk Material Library 2014 - Medium Image LibraryFailedInstallation aborted, Result=1618
2013/10/16:11:50:47MahonriMAHONRI-PCRollbackDirectX® RuntimeFailedFailure is ignored, Result=1619
See attached the log of the installation. If any direction can be offered in this situation I would be very grateful for the guidance.
M
Any 16## errors are very trick to solve. I would start with permissions.
1. Use Procmon to analyze the error.
2. Then check the file using the workflow noted below:
http://upandready.typepad.com/up_and_ready/2013/09/revit-crash-at-startup.html
