I tried several times to install REVIT 2014 in different ways(install now/download then install) but every time there is just no option of installing REVIT 2014. So all I installed is license manager or manager tools but never able to install the software itself. Does anyone know what this problem is? Why is the option for install REVIT 2014 missing? I'm pretty sure that my laptop hardare fits the requirement so why is this happening and how to solve it? Thanks!
Solved by dembkod. Go to Solution.
Based on the screen capture that you've provided, it appears you click the Install Tools & Utilities option on the initial install page. In order to install Revit 2014, you need to click the Install option, which is on the right side of the initial install page.
Tony Michniewicz
Autodesk Revit QA
