My system is Windows8 and the installtion process stops every time when it starts install visual C++ 2005 redistribu...Can anybody help me to solve the problem? I really need the program to work with a project due in 5 days! Thanks a loooooooot!
Here is the log file:
2013/9/5:15:08:18 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:08:18 Kong MAY Path_Length: 149
2013/9/5:15:08:18 Kong MAY Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/9/5:15:08:18 Kong MAY Launch
2013/9/5:15:08:18 Kong MAY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2013/9/5:15:08:18 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI49C4.tmp
2013/9/5:15:13:29 Kong MAY === Setup ended ===
2013/9/5:15:08:24 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:08:24 Kong MAY Path_Length: 149
2013/9/5:15:08:24 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI49C4.tmp
2013/9/5:15:08:24 Kong MAY Launch
2013/9/5:15:09:10 Kong MAY Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/9/5:15:13:29 Kong MAY Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/9/5:15:13:29 Kong MAY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Kong\AppData\Local\Temp\_AI49C4.tmp\Setup\RevitSetup.dll
2013/9/5:15:13:29 Kong MAY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/5:15:13:29 Kong MAY PageOpen LaunchDialog
2013/9/5:15:13:46 Kong MAY PageOpen LicenseDialog
2013/9/5:15:13:51 Kong MAY PageOpen ProductInfoDialog
2013/9/5:15:20:14 Kong MAY === Setup ended ===
2013/9/5:15:20:47 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:20:47 Kong MAY Path_Length: 149
2013/9/5:15:20:47 Kong MAY Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/9/5:15:20:47 Kong MAY Launch
2013/9/5:15:20:47 Kong MAY CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64... /SN 900-41115723 /PK 829F1 /student /skipEULA /akamai /auth /sid
2013/9/5:15:20:48 Kong MAY Path_Length: 149
2013/9/5:15:20:48 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AIBAF7.tmp
2013/9/5:15:21:13 Kong MAY === Setup ended ===
2013/9/5:15:20:50 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:20:50 Kong MAY Path_Length: 149
2013/9/5:15:20:50 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AIBAF7.tmp
2013/9/5:15:20:50 Kong MAY Launch
2013/9/5:15:20:51 Kong MAY Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/9/5:15:21:12 Kong MAY Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/9/5:15:21:12 Kong MAY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Kong\AppData\Local\Temp\_AIBAF7.tmp\Setup\RevitSetup.dll
2013/9/5:15:21:13 Kong MAY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/5:15:21:13 Kong MAY PageOpen LaunchDialog
2013/9/5:15:23:19 Kong MAY PageOpen LicenseDialog
2013/9/5:15:23:19 Kong MAY PageOpen ProductInfoDialog
2013/9/5:15:23:19 Kong MAY PageOpen ProductSelectionDialog2
2013/9/5:15:23:29 Kong MAY PageOpen FullProgressDialog
2013/9/5:15:23:30 Kong MAY Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/9/5:15:23:31 Kong MAY Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/9/5:15:23:31 Kong MAY Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kong\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/9/5:15:23:44 Kong MAY Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/9/5:15:23:44 Kong MAY PageOpen InstallCompleteDialog
2013/9/5:15:23:55 Kong MAY === Setup ended ===
2013/9/5:15:26:51 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:26:51 Kong MAY Path_Length: 149
2013/9/5:15:26:51 Kong MAY Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/9/5:15:26:51 Kong MAY Launch
2013/9/5:15:26:51 Kong MAY CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64... /SN 900-41115723 /PK 829F1 /student /skipEULA /akamai /auth /sid
2013/9/5:15:26:51 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI45AB.tmp
2013/9/5:15:27:01 Kong MAY === Setup ended ===
2013/9/5:15:26:56 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:26:56 Kong MAY Path_Length: 149
2013/9/5:15:26:56 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI45AB.tmp
2013/9/5:15:26:56 Kong MAY Launch
2013/9/5:15:26:56 Kong MAY Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/9/5:15:26:56 Kong MAY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Kong\AppData\Local\Temp\_AI45AB.tmp\Setup\RevitSetup.dll
2013/9/5:15:26:56 Kong MAY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/5:15:26:58 Kong MAY PageOpen LaunchDialog
2013/9/5:15:29:48 Kong MAY PageOpen LicenseDialog
2013/9/5:15:29:48 Kong MAY PageOpen ProductInfoDialog
2013/9/5:15:29:48 Kong MAY PageOpen ProductSelectionDialog2
2013/9/5:15:31:57 Kong MAY PageOpen FullProgressDialog
2013/9/5:15:31:57 Kong MAY Download Skipped VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/9/5:15:31:57 Kong MAY Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kong\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/9/5:15:32:04 Kong MAY Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/9/5:15:32:04 Kong MAY PageOpen InstallCompleteDialog
2013/9/5:15:32:20 Kong MAY === Setup ended ===
2013/9/5:15:35:55 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:35:55 Kong MAY Path_Length: 149
2013/9/5:15:35:55 Kong MAY Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/9/5:15:35:55 Kong MAY Launch
2013/9/5:15:35:55 Kong MAY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2013/9/5:15:35:55 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI92F9.tmp
2013/9/5:15:36:03 Kong MAY === Setup ended ===
2013/9/5:15:35:58 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:35:58 Kong MAY Path_Length: 149
2013/9/5:15:35:58 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI92F9.tmp
2013/9/5:15:35:58 Kong MAY Launch
2013/9/5:15:35:59 Kong MAY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/9/5:15:35:59 Kong MAY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Kong\AppData\Local\Temp\_AI92F9.tmp\Setup\RevitSetup.dll
2013/9/5:15:35:59 Kong MAY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/5:15:36:00 Kong MAY PageOpen LaunchDialog
2013/9/5:15:36:06 Kong MAY PageOpen LicenseDialog
2013/9/5:15:36:25 Kong MAY PageOpen ProductInfoDialog
2013/9/5:15:38:28 Kong MAY PageOpen ProductSelectionDialog2
2013/9/5:15:38:39 Kong MAY PageOpen FullProgressDialog
2013/9/5:15:38:40 Kong MAY Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2013/9/5:15:39:11 Kong MAY Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2013/9/5:15:39:11 Kong MAY Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kong\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/9/5:15:39:18 Kong MAY Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/9/5:15:39:18 Kong MAY PageOpen InstallCompleteDialog
2013/9/5:15:41:51 Kong MAY === Setup ended ===
2013/9/5:15:50:52 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:50:52 Kong MAY Path_Length: 149
2013/9/5:15:50:52 Kong MAY Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/9/5:15:50:52 Kong MAY Launch
2013/9/5:15:50:52 Kong MAY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2013/9/5:15:50:52 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI45FE.tmp
2013/9/5:15:51:02 Kong MAY === Setup ended ===
2013/9/5:15:50:56 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:15:50:56 Kong MAY Path_Length: 149
2013/9/5:15:50:56 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AI45FE.tmp
2013/9/5:15:50:56 Kong MAY Launch
2013/9/5:15:50:58 Kong MAY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/9/5:15:50:58 Kong MAY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Kong\AppData\Local\Temp\_AI45FE.tmp\Setup\RevitSetup.dll
2013/9/5:15:50:58 Kong MAY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/5:15:50:59 Kong MAY PageOpen LaunchDialog
2013/9/5:15:51:06 Kong MAY PageOpen LicenseDialog
2013/9/5:15:51:10 Kong MAY PageOpen ProductInfoDialog
2013/9/5:15:53:10 Kong MAY PageOpen ProductSelectionDialog2
2013/9/5:15:53:19 Kong MAY PageOpen FullProgressDialog
2013/9/5:15:53:19 Kong MAY Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2013/9/5:15:53:19 Kong MAY Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kong\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/9/5:15:53:26 Kong MAY Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2013/9/5:15:53:27 Kong MAY PageOpen InstallCompleteDialog
2013/9/5:15:53:32 Kong MAY === Setup ended ===
2013/9/5:16:45:54 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:16:45:54 Kong MAY Path_Length: 149
2013/9/5:16:45:54 Kong MAY Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/9/5:16:45:54 Kong MAY Launch
2013/9/5:16:45:54 Kong MAY CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2013/9/5:16:45:54 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AIA764.tmp
2013/9/5:16:46:01 Kong MAY === Setup ended ===
2013/9/5:16:45:56 Kong MAY === Setup started on MAY by Kong ===
2013/9/5:16:45:56 Kong MAY Path_Length: 149
2013/9/5:16:45:56 Kong MAY Current Directory C:\Users\Kong\AppData\Local\Temp\_AIA764.tmp
2013/9/5:16:45:56 Kong MAY Launch
2013/9/5:16:45:57 Kong MAY Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/9/5:16:45:57 Kong MAY Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Kong\AppData\Local\Temp\_AIA764.tmp\Setup\RevitSetup.dll
2013/9/5:16:45:57 Kong MAY Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/9/5:16:45:57 Kong MAY PageOpen LaunchDialog
2013/9/5:16:46:14 Kong MAY PageOpen LicenseDialog
2013/9/5:16:46:20 Kong MAY PageOpen ProductInfoDialog
2013/9/5:16:49:00 Kong MAY PageOpen ProductSelectionDialog2
2013/9/5:16:50:34 Kong MAY PageOpen FullProgressDialog
2013/9/5:16:50:34 Kong MAY Download Skipped VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2013/9/5:16:50:34 Kong MAY Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Kong\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/9/5:16:50:40 Kong MAY Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
For additional information, please consider using Search to assist in your resolution:
Search Autodesk.com
Search Autodesk Discussion Groups
Search Up and Ready Blog
Search Autodesk WikiHelp
DarrenP
Welcome to the community.
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
Good Luck!
if these don't work try creating another windows user on that machine with administrator permissons and install
DarrenP
Hello. First I would UNINSTALL all C++ redistributables on the system for 2005, 2008, and 2010 and then try to install. Past this, I would modify the setup.ini and see if you can get past this. Make a backup copy of your existing Setup.ini file and then edit the original setup.ini.
Replace all instances of PREREQUISITES with #PREREQUISITES and save the file. Now install. This will avoid trying to install the prerequisites.
You can always manually install the reqs from the 3rd party folder in the installer.
Thank you for taking part in our community!
Here is my log file for an extra laptop one of our engineers uses. Does anyone know what the issue is?
It looks like its all good until the red portion below
2013/10/29:09:15:12 byce 1208KALP === Setup started on 1208KALP by byce ===
2013/10/29:09:15:12 byce 1208KALP Path_Length: 149
2013/10/29:09:15:12 byce 1208KALP Current Directory \\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img
2013/10/29:09:15:12 byce 1208KALP Launch
2013/10/29:09:15:12 byce 1208KALP CommandLine /qb /I \\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\Master Premium.ini /language en-us
2013/10/29:09:15:13 byce 1208KALP Path_Length: 149
2013/10/29:09:15:13 byce 1208KALP Current Directory C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AID7A9.tmp
2013/10/29:09:21:13 byce 1208KALP === Setup ended ===
2013/10/29:09:16:32 byce 1208KALP === Setup started on 1208KALP by byce ===
2013/10/29:09:16:32 byce 1208KALP Path_Length: 149
2013/10/29:09:16:32 byce 1208KALP Current Directory C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AID7A9.tmp
2013/10/29:09:16:32 byce 1208KALP Launch
2013/10/29:09:16:35 byce 1208KALP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AID7A9.tmp\Setup\RevitSetup.dll
2013/10/29:09:16:35 byce 1208KALP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:09:20:24 byce 1208KALP Installing Microsoft Visual C++ 2005 Redistributable (x86): "\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\BYCE~1.BYC\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/10/29:09:20:39 byce 1208KALP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/10/29:09:20:39 byce 1208KALP Installing .NET Framework Runtime 4.5: "\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe" /q /norestart
2013/10/29:09:27:01 byce 1208KALP Install .NET Framework Runtime 4.5 Succeeded
2013/10/29:09:27:01 byce 1208KALP Installing DirectX® Runtime: "\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/29:09:36:44 byce 1208KALP Install DirectX® Runtime Succeeded
2013/10/29:09:36:55 byce 1208KALP Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:09:37:31 byce 1208KALP Install FaroSDK Succeeded
2013/10/29:09:37:31 byce 1208KALP Installing Autodesk® Revit® 2014: TRANSFORMS="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\x64\en-us\RVT2014\RVT2014.mst;\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\x64\RVT2014\RVT2014-Master Premium.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=",Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2005 Redistributable (x86),Microsoft Visual C++ 2005 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,DirectX® Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},;{11672AB2-3D48-4D38-9123-719E5FF93333},{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{5C29CC1F-218F-4C30-948A-11066CAC59FB},;;" ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:10:36:07 byce 1208KALP Install Autodesk® Revit® 2014 Succeeded
2013/10/29:10:36:12 byce 1208KALP Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AID7A9.tmp\_laF20F.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" ADLM_EULA_COUNTRY=US INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:10:36:15 byce 1208KALP Install Autodesk® Revit® 2014 Language Pack Failed Installation aborted, Result=1603
2013/10/29:10:39:17 byce 1208KALP Rollback Autodesk® Revit® 2014 Succeeded
2013/10/29:10:39:20 byce 1208KALP Rollback FaroSDK Succeeded
2013/10/29:10:39:20 byce 1208KALP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/10/29:10:39:20 byce 1208KALP Rollback .NET Framework Runtime 4.5 Failed Failure is ignored, Result=1619
2013/10/29:10:39:20 byce 1208KALP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2013/10/29:10:53:54 byce 1208KALP === Setup ended ===
2013/10/29:10:54:35 byce 1208KALP === Setup started on 1208KALP by byce ===
2013/10/29:10:54:35 byce 1208KALP Path_Length: 149
2013/10/29:10:54:35 byce 1208KALP Current Directory \\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img
2013/10/29:10:54:35 byce 1208KALP Launch
2013/10/29:10:54:35 byce 1208KALP CommandLine /qb /I \\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\Master Premium.ini /language en-us
2013/10/29:10:54:37 byce 1208KALP Path_Length: 149
2013/10/29:10:54:37 byce 1208KALP Current Directory C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp
2013/10/29:11:09:29 byce 1208KALP === Setup ended ===
2013/10/29:10:57:41 byce 1208KALP === Setup started on 1208KALP by byce ===
2013/10/29:10:57:41 byce 1208KALP Path_Length: 149
2013/10/29:10:57:41 byce 1208KALP Current Directory C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp
2013/10/29:10:57:41 byce 1208KALP Launch
2013/10/29:10:57:48 byce 1208KALP Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp\Setup\RevitSetup.dll
2013/10/29:10:57:48 byce 1208KALP Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/29:11:06:37 byce 1208KALP Installing DirectX® Runtime: "\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/29:11:26:08 byce 1208KALP Install DirectX® Runtime Succeeded
2013/10/29:11:26:35 byce 1208KALP Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" ADLM_EULA_COUNTRY=US FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:11:27:34 byce 1208KALP Install FaroSDK Succeeded
2013/10/29:11:27:34 byce 1208KALP Installing Autodesk® Revit® 2014: TRANSFORMS="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\x64\en-us\RVT2014\RVT2014.mst;\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\x64\RVT2014\RVT2014-Master Premium.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=",Internet Explorer 7,SSE2 Support Check,Microsoft Visual C++ 2008 SP1 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161,Microsoft Visual C++ 2005 Redistributable (x86),Microsoft Visual C++ 2005 Redistributable (x64),Microsoft Visual C++ 2008 SP1 Redistributable (x86),Microsoft Visual C++ 2008 SP1 Redistributable (x86) 9.0.30729.6161,Microsoft Visual C++ 2010 SP1 Redistributable (x86),Microsoft Visual C++ 2010 SP1 Redistributable (x64),{04B34E21-5BEE-3D2B-8D3D-E3E80D253F64},{B42E259C-E4D4-37F1-A1B2-EB9C4FC5A04D},{14866AAD-1F23-39AC-A62B-7091ED1ADE64},{4B90093A-5D9C-3956-8ABB-95848BE6EFAD},{C3A57BB3-9AA6-3F6F-9395-6C062BDD5FC4},{6DA2B636-698A-3294-BF4A-B5E11B238CDD},{F6F09DD8-F39B-3A16-ADB9-C9E6B56903F9},{8CCEA24C-51AE-3B71-9092-7D0C44DDA2DF},Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86),Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64),.NET Framework Runtime 3.5 SP1,.NET Framework Runtime 4.5,.NET Framework Runtime 4.5 Language pack,DirectX® Runtime,{8A470330-70B2-49AD-86AF-79885EF9898A},;{11672AB2-3D48-4D38-9123-719E5FF93333},{644F9B19-A462-499C-BF4D-300ABC2A28B1},{51BF3210-B825-4092-8E0D-66D689916E02},{5C29CC1F-218F-4C30-948A-11066CAC59FB},;;" ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:12:47:44 byce 1208KALP Install Autodesk® Revit® 2014 Succeeded
2013/10/29:12:47:50 byce 1208KALP Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\BYCE~1.BYC\AppData\Local\Temp\_AICA81.tmp\_la716E.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="\\0709KBNAS\Shared\Program Files\AutoDesk Install\Deployment\Img\" ADLM_EULA_COUNTRY=US INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/29:12:47:52 byce 1208KALP Install Autodesk® Revit® 2014 Language Pack Failed Installation aborted, Result=1603
2013/10/29:12:51:07 byce 1208KALP Rollback Autodesk® Revit® 2014 Succeeded
2013/10/29:12:51:09 byce 1208KALP Rollback FaroSDK Succeeded
2013/10/29:12:51:09 byce 1208KALP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/10/29:13:04:05 byce 1208KALP === Setup ended ===
Hello. You are failing on installing the language pack. It does not tell us exactly why you are failing, but does give an area to focus on.
You first should try to UNISNTALL the language pack using the MS fixit tool from here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
This may clean out your failed installation of the language pack and allow your install to proceed. Past this, I would look at the Windows Event log and see if anything sticks out.
i have the same problem, i tried to install revit 2014 and after I got installed 2.2 GB, the installation was aborted
what do i have to do???
2013/12/22:08:41:20 AdánAníbal ADÁN-HERRERA === Setup started on ADÁN-HERRERA by AdánAníbal ===
2013/12/22:08:41:20 AdánAníbal ADÁN-HERRERA Path_Length: 149
2013/12/22:08:41:20 AdánAníbal ADÁN-HERRERA Current Directory C:\Users\ADNANB~1\AppData\Local\Temp\_AI6AD0.tmp
2013/12/22:08:41:20 AdánAníbal ADÁN-HERRERA Launch
2013/12/22:08:41:21 AdánAníbal ADÁN-HERRERA Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2013/12/22:08:43:32 AdánAníbal ADÁN-HERRERA Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2013/12/22:08:43:32 AdánAníbal ADÁN-HERRERA Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\ADNANB~1\AppData\Local\Temp\_AI6AD0.tmp\Setup\RevitSetup.dll
2013/12/22:08:43:32 AdánAníbal ADÁN-HERRERA Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/12/22:08:43:33 AdánAníbal ADÁN-HERRERA PageOpen LaunchDialog
2013/12/22:08:59:51 AdánAníbal ADÁN-HERRERA PageOpen LicenseDialog
2013/12/22:09:03:35 AdánAníbal ADÁN-HERRERA PageOpen ProductInfoDialog
2013/12/22:09:03:35 AdánAníbal ADÁN-HERRERA PageOpen ProductSelectionDialog2
2013/12/22:09:03:38 AdánAníbal ADÁN-HERRERA PageOpen FullProgressDialog
2013/12/22:09:03:39 AdánAníbal ADÁN-HERRERA Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2013/12/22:09:03:58 AdánAníbal ADÁN-HERRERA Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/DIRECTX....
2013/12/22:09:03:58 AdánAníbal ADÁN-HERRERA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/12/22:09:04:01 AdánAníbal ADÁN-HERRERA Install DirectX® Runtime Succeeded
2013/12/22:09:04:02 AdánAníbal ADÁN-HERRERA Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2013/12/22:10:07:28 AdánAníbal ADÁN-HERRERA Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/RVT2014_...
2013/12/22:10:07:28 AdánAníbal ADÁN-HERRERA Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2013/12/22:10:07:29 AdánAníbal ADÁN-HERRERA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
