It has been several days and I've tried almost everything from editing my setup.ini, uninstalling most of my Microsoft Visual C++, and set registry size to unlimited and rebooting.
Here is my installation log:
2013/12/29:17:00:24 JUN JUN-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Failed Installation aborted, Result=1603
2013/12/29:17:00:24 JUN JUN-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/12/29:17:00:24 JUN JUN-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
The whole log is attached below.
Thanks in advance!
Can you try the following before re-installing the software?
http://upandready.typepad.com/up_and_ready/2013/04/quick-start-general-installation-workflow.html
This is an old thread. Can you post a new one with your own installation log file?
this is my log file , please help as soon as possible
2014/12/9:17:08:31 ahmed-magdi AHMED === Setup started on AHMED by ahmed-magdi ===
2014/12/9:17:08:31 ahmed-magdi AHMED Launch
2014/12/9:17:08:53 ahmed-magdi AHMED === Setup ended ===
2014/12/9:17:08:34 ahmed-magdi AHMED === Setup started on AHMED by ahmed-magdi ===
2014/12/9:17:08:34 ahmed-magdi AHMED Launch
2014/12/9:17:08:55 ahmed-magdi AHMED PageOpen LaunchDialog
2014/12/9:17:09:00 ahmed-magdi AHMED PageOpen LicenseDialog
2014/12/9:17:09:10 ahmed-magdi AHMED PageOpen ProductInfoDialog
2014/12/9:17:09:24 ahmed-magdi AHMED PageOpen ProductSelectionDialog2
2014/12/9:17:09:30 ahmed-magdi AHMED PageOpen FullProgressDialog
2014/12/9:17:09:30 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 Redistributable (x64): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x64\VCRedist\2008\install.exe /q /l C:\Users\AHMED-~1\AppData\Local\Temp\vcredist_x64_2008.log
2014/12/9:17:09:42 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 Redistributable (x64) Succeeded
2014/12/9:17:09:42 ahmed-magdi AHMED Installing Microsoft Visual C++ 2005 Redistributable (x86): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMED-~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/12/9:17:09:56 ahmed-magdi AHMED Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/12/9:17:09:56 ahmed-magdi AHMED Installing Microsoft Visual C++ 2005 Redistributable (x64): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x64\VCRedist\2005\vcredist_x64.exe /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMED-~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/12/9:17:10:26 ahmed-magdi AHMED Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/12/9:17:10:26 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 Redistributable (x86): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x86\VCRedist\2008\install.exe /q /l C:\Users\AHMED-~1\AppData\Local\Temp\vcredist_x86_2008.log
2014/12/9:17:10:33 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 Redistributable (x86) Succeeded
2014/12/9:17:10:33 ahmed-magdi AHMED Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2014/12/9:17:10:43 ahmed-magdi AHMED Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/12/9:17:10:43 ahmed-magdi AHMED Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2014/12/9:17:10:56 ahmed-magdi AHMED Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/12/9:17:10:56 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:01 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/12/9:17:11:01 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:10 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/12/9:17:11:10 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:19 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/12/9:17:11:19 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:27 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/12/9:17:11:27 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:31 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/12/9:17:11:31 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:42 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/12/9:17:11:42 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:50 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/12/9:17:11:50 ahmed-magdi AHMED Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/12/9:17:11:57 ahmed-magdi AHMED Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/12/9:17:11:57 ahmed-magdi AHMED Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMED-~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/12/9:17:12:25 ahmed-magdi AHMED Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/12/9:17:12:25 ahmed-magdi AHMED Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): E:\sources\Autodesk_Revit_2013_English_Win_32-64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\AHMED-~1\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/12/9:17:12:47 ahmed-magdi AHMED Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/12/9:17:12:47 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/12/9:17:12:52 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/12/9:17:12:56 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/12/9:17:13:00 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/12/9:17:13:03 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/12/9:17:13:07 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/12/9:17:13:11 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/12/9:17:13:16 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 Redistributable (x86) Failed Installation aborted, Result=1619
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/12/9:17:13:19 ahmed-magdi AHMED Rollback Microsoft Visual C++ 2008 Redistributable (x64) Failed Installation aborted, Result=1619
Start here:
