Installation & Licensing
Revit 2014 Failed to Install
2 REPLIES 2
609 Views, 2 Replies
I tried to install Revit 2014 (student version if that makes a difference), but it failed on my computer. I got the results 1603 and 1619. The whole report is attached.
2 REPLIES 2
drp281
TravisNave
The materials library isn't installing.  It could be an existing SQL issue if you already have a library installed from a previous version.
In any case, do not install the materials library yet.  Uncheck it and let everything else install first so that it won't roll back the entire package. After that you can work on fixing the reason for the library failing.
Install	Autodesk Material Library 2014 - Medium Image Library	Failed	Download Failed, Installation aborted, Result=1603
Looks like the error shows it is a failed download.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
