I tried to install Revit 2014 (student version if that makes a difference), but it failed on my computer. I got the results 1603 and 1619. The whole report is attached.
Solved by drp281. Go to Solution.
a starting point for error 1603: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=error+1603&search_submit...
and error 1619: http://forums.autodesk.com/t5/forums/searchpage/tab/message?q=error+1619&filter=labels
The materials library isn't installing. It could be an existing SQL issue if you already have a library installed from a previous version.
In any case, do not install the materials library yet. Uncheck it and let everything else install first so that it won't roll back the entire package. After that you can work on fixing the reason for the library failing.
Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
Looks like the error shows it is a failed download.
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
