Installation & Licensing
New Member
i.baker
Message 1 of 15 (1,476 Views)
Revit 2014 error on Startup
1476 Views, 14 Replies
10-24-2013 08:39 PM
Hi
I'm geting a problem on startup of Revit 2014 on serveral PCs:
'Default External Servers not available'
'Revit cannot find the default servers for the external services:
"Duct/Fitting Accessory Pressure Drop Calculator"
(long string of letters and numbers) by vendor "ADSK"
"Pipe/Fitting Accessory Pressure Drop Calculator"
"Pipe Pressure Drop Calculator"
 "Plumbing flow calculator"
The following errors are logged in the journal file:
' 0:< DBG_WARN: The public key has been broken up. And the last error is 0.: line 32 of AddIn\AddInVerificationManager.cpp.
' 0:< DBG_WARN: Can't get cryptography provider.: line 37 of AddIn\AddInVerificationManager.cpp.
' 0:< DBG_WARN: Can't import public key!: line 46 of AddIn\AddInVerificationManager.cpp.
' 0:< DBG_INFO: A mandatory external service is missing its default server.Name(Duct Fitting/Accessory Pressure Drop Calculator), VendorId(ADSK), ServiceId(785d0bd7-3088-489a-af7a-593fc32e2540): line 258 of ExternalServices\ExternalServicesManager.cpp.
This happens with and without the Revit 2014 service pack installed, with different user accounts.
Does anyone have any ideas?
Thanks for the help
Product Support
david.lau
Message 2 of 15 (1,440 Views)
Re: Revit 2014 error on Startup
10-25-2013 10:23 AM in reply to: i.baker
Can you try the following steps:
1.  Repair installation
2.  Uninstall/ reinstall. (make sure installer is run as admin or has elevated privileges).  When you re-run setup, right mouse click on it and choose "Run As Administrator".
Thanks to the Revit Guru Chris Aquino to the tip/workflow.
David Lau
New Member
kmwright.asu
Message 3 of 15 (1,300 Views)
10-30-2013 01:42 PM in reply to: i.baker
We're having the same issue, we're you able to resolve it?
If you log in as the local machine administrator the program runs fine.  Any other account and the error pops up.
-Kyle W.
Product Support
david.lau
Message 4 of 15 (1,276 Views)
11-04-2013 07:13 AM in reply to: kmwright.asu
Are you using Mandatory Profiles?  I am told from the Revit QA that this is a setup that has not been tested with Revit.
http://msdn.microsoft.com/en-us/library/windows/desktop/bb776895(v=vs.85).aspx
David Lau
New Member
kmwright.asu
Message 5 of 15 (1,269 Views)
11-04-2013 07:33 AM in reply to: i.baker
Indeed, we are using mandatory profiles.  My guess is it's related to that, and something is installed in the profile at installation.  I copied much of the main user profile into our mandatory profile and was unable to get it to work though.
For now we just have it set to ignore\bypass the error as students report that the software still works as they need.
-Kyle
New Member
grantdzaman
Message 6 of 15 (1,186 Views)
12-10-2013 02:56 PM in reply to: i.baker
I am receiving this error after the installation of update release 2 for Revit 2014.
The error is on the start page of Revit.
Looks like the update release 2 is creating the problem.
Let me know if a solution exists.
 Look at attached error
Active Member
iceman1849
Message 7 of 15 (1,122 Views)
12-21-2013 11:27 AM in reply to: i.baker
I'm having an issue with Autodesk Revit 2014 "Cannot find default servers for external services" I'm not using mandatory user profiles, I'm not connected to a server. I did download to the service pack 2. Has anyone find a solution for this? I'm getting ready for a class on Revit MEP 2014 and need the duct fitting, pipe, plumbing flow calculators to work.
I appreciate any assistance.
Thanks Brian
iceman1849@aol.com
New Member
ROCMNTAB
Message 8 of 15 (1,009 Views)
01-20-2014 12:21 AM in reply to: i.baker
I've got the same problem. I can't figure out why, Some clients have no issue  but then some do....
Same admin point, can anyone help?
I would settle with blocking this error for the user because they don't use it anyway. (i think)
New Member
lajansen
Message 9 of 15 (689 Views)
04-10-2014 12:43 AM in reply to: ROCMNTAB
the error can be suppresed by the ini file in the appdata folder of the user you find the revit.ini adding the line [DSNM] Launching Revit With Invalid Services=1001 prevents the message from poping up
New Member
ROCMNTAB
Message 10 of 15 (684 Views)
04-10-2014 01:19 AM in reply to: i.baker
Thanks, i'll try that! :smileyhappy:
