2013/10/3:20:15:03 Lenovo CHANDRASHEKAR === Setup started on CHANDRASHEKAR by Lenovo ===
2013/10/3:20:15:03 Lenovo CHANDRASHEKAR Path_Length: 149
2013/10/3:20:15:03 Lenovo CHANDRASHEKAR Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/10/3:20:15:03 Lenovo CHANDRASHEKAR Launch
2013/10/3:20:15:03 Lenovo CHANDRASHEKAR CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64... /SN 900-40484331 /PK 829F1 /student /skipEULA /akamai /auth /sid
2013/10/3:20:15:03 Lenovo CHANDRASHEKAR Current Directory C:\Users\Lenovo\AppData\Local\Temp\_AI2136.tmp
2013/10/3:20:18:57 Lenovo CHANDRASHEKAR === Setup ended ===
2013/10/3:20:15:05 Lenovo CHANDRASHEKAR === Setup started on CHANDRASHEKAR by Lenovo ===
2013/10/3:20:15:05 Lenovo CHANDRASHEKAR Path_Length: 149
2013/10/3:20:15:05 Lenovo CHANDRASHEKAR Current Directory C:\Users\Lenovo\AppData\Local\Temp\_AI2136.tmp
2013/10/3:20:15:05 Lenovo CHANDRASHEKAR Launch
2013/10/3:20:17:59 Lenovo CHANDRASHEKAR Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:18:56 Lenovo CHANDRASHEKAR Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:18:57 Lenovo CHANDRASHEKAR Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Lenovo\AppData\Local\Temp\_AI2136.tmp\Setup\RevitSetup.dll
2013/10/3:20:18:57 Lenovo CHANDRASHEKAR Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/10/3:20:18:57 Lenovo CHANDRASHEKAR PageOpen LaunchDialog
2013/10/3:20:24:17 Lenovo CHANDRASHEKAR PageOpen LicenseDialog
2013/10/3:20:24:17 Lenovo CHANDRASHEKAR PageOpen ProductInfoDialog
2013/10/3:20:24:17 Lenovo CHANDRASHEKAR PageOpen ProductSelectionDialog2
2013/10/3:20:29:19 Lenovo CHANDRASHEKAR PageOpen FullProgressDialog
2013/10/3:20:29:21 Lenovo CHANDRASHEKAR Download Play VCREDIST2008SP1X64_6161 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:29:30 Lenovo CHANDRASHEKAR Download Complete VCREDIST2008SP1X64_6161 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:29:30 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1.6161\vcredist_x64.exe" /q
2013/10/3:20:29:41 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) 9.0.30729.6161 Succeeded
2013/10/3:20:29:43 Lenovo CHANDRASHEKAR Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:29:48 Lenovo CHANDRASHEKAR Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:29:48 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Lenovo\AppData\Local\Temp\vcredist_x86_2005.log"" "
2013/10/3:20:29:57 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2013/10/3:20:29:58 Lenovo CHANDRASHEKAR Download Play VCREDIST2005X64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:04 Lenovo CHANDRASHEKAR Download Complete VCREDIST2005X64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:04 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Lenovo\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/10/3:20:30:18 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/10/3:20:30:19 Lenovo CHANDRASHEKAR Download Play KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:20 Lenovo CHANDRASHEKAR Download Complete KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:20 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:30:23 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/10/3:20:30:24 Lenovo CHANDRASHEKAR Download Play KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:34 Lenovo CHANDRASHEKAR Download Complete KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:34 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:30:43 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/10/3:20:30:44 Lenovo CHANDRASHEKAR Download Play KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:46 Lenovo CHANDRASHEKAR Download Complete KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:46 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:30:49 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/10/3:20:30:51 Lenovo CHANDRASHEKAR Download Play KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:51 Lenovo CHANDRASHEKAR Download Complete KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:51 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:30:53 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/10/3:20:30:55 Lenovo CHANDRASHEKAR Download Play KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:55 Lenovo CHANDRASHEKAR Download Complete KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:30:55 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:30:56 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/10/3:20:30:58 Lenovo CHANDRASHEKAR Download Play KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:31:09 Lenovo CHANDRASHEKAR Download Complete KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:31:09 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:31:14 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/10/3:20:31:16 Lenovo CHANDRASHEKAR Download Play KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:31:18 Lenovo CHANDRASHEKAR Download Complete KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:31:18 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:31:21 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/10/3:20:31:22 Lenovo CHANDRASHEKAR Download Play KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:31:23 Lenovo CHANDRASHEKAR Download Complete KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:31:23 Lenovo CHANDRASHEKAR Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:31:25 Lenovo CHANDRASHEKAR Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/10/3:20:31:26 Lenovo CHANDRASHEKAR Download Play DOTNET45 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:35:57 Lenovo CHANDRASHEKAR Download Complete DOTNET45 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:35:57 Lenovo CHANDRASHEKAR Installing .NET Framework Runtime 4.5: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe" /q /norestart
2013/10/3:20:41:36 Lenovo CHANDRASHEKAR Install .NET Framework Runtime 4.5 Succeeded
2013/10/3:20:41:41 Lenovo CHANDRASHEKAR Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:41:51 Lenovo CHANDRASHEKAR Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:41:51 Lenovo CHANDRASHEKAR Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/10/3:20:42:36 Lenovo CHANDRASHEKAR Install DirectX® Runtime Succeeded
2013/10/3:20:42:36 Lenovo CHANDRASHEKAR Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:20:43:04 Lenovo CHANDRASHEKAR Install FaroSDK Succeeded
2013/10/3:20:43:05 Lenovo CHANDRASHEKAR Download Play RVT2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:58:16 Lenovo CHANDRASHEKAR Download Aborted RVT2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/10/3:20:58:43 Lenovo CHANDRASHEKAR Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Lenovo\AppData\Local\Temp\_AI2136.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/10/3:21:04:59 Lenovo CHANDRASHEKAR Install Autodesk® Revit® 2014 Failed Installation aborted, Result=1603
2013/10/3:21:05:03 Lenovo CHANDRASHEKAR Rollback FaroSDK Succeeded
2013/10/3:21:05:03 Lenovo CHANDRASHEKAR Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/10/3:21:05:03 Lenovo CHANDRASHEKAR Rollback .NET Framework Runtime 4.5 Failed Installation aborted, Result=1619
2013/10/3:21:05:05 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/10/3:21:05:06 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/10/3:21:05:07 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/10/3:21:05:08 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/10/3:21:05:10 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/10/3:21:05:11 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/10/3:21:05:12 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/10/3:21:05:13 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/10/3:21:05:14 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2013/10/3:21:05:14 Lenovo CHANDRASHEKAR Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
try reading thorugh this: http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
DarrenP
or read through any of these: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=error+1819#/?q=error+161...
DarrenP
Looks like your download is aborting.
You might want to download the software manually from the virtual assistant.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889745&linkID=9240617
Good Luck!
